  • 1.  Interface management msr2000
    Posted Jan 28, 2016 08:48 PM
    Hi all
    I've setup eth0 as trunk and VLAN 212 native also as a management interface. I ping from VLAN 211 unreachable, What about false in my config?
    I hope can help me
  • 2.  RE: Interface management msr2000
    Posted Jan 28, 2016 09:45 PM
    You could post your config, otherwise I would assume either the management IP is not set correctly or the switch uplink isn't correct.
  • 3.  RE: Interface management msr2000
    Posted Jan 30, 2016 08:44 AM
    Thank's jerrod
    Here's my config, by the way the switch I used catalyst.
    Attachment(s)
    txt
    TEST TRUNK.txt   5 KB 1 version
  • 4.  RE: Interface management msr2000
    Posted Jan 30, 2016 10:32 AM
    I don't see a default gateway, so are you trying to access the AP from the same subnet? Is this an old or a new MSR? Have you connected your laptop directly to it through a power injector and then can you see 212? If you change the port to access on 212, can you then see it?
    Here is what my lab setup looks like, SSID carries on 150, management is on 100.
    interface gigabit-ethernet 0
    mode gateway
    switchport trunk allowed-vlan 100,150
    switchport trunk native vlan 100
    interface loopback 0
    ip address from-mac
    router-id
    interface vlan 1
    management
    mtu 1500
    interface vlan 100
    ip address 192.168.100.211/24
    mtu 1500
    ip route 0.0.0.0/0 192.168.100.254
    local-ip 192.168.216.1/24
