Interpret CLI Diagnostic Commands
  • 1.  Interpret CLI Diagnostic Commands
    Posted May 13, 2015 06:36 PM
    show ap debug client-table ap-name "primary"
    Part of the output of this command: UAPSD:(VO,VI,BK,BE,Max SP,Q Len) 0,0,0,0,N/A,0 - this is an example (what if the zeros are ones?)
    My question: where can I find a discussion about CLI diagnostic commands. I have a list I created but expert help with this subject is most appreciated.
    Thanks kindly, Paul
  • 2.  RE: Interpret CLI Diagnostic Commands
    Posted Sep 03, 2015 03:51 AM
    hi Paul
    if they are all zeroes then either
    a> client does not support UAPSD
    b> UAPSD is disabled on ssid profile
    c> client has UAPSD disable (i.e. recent intel 7260 drivers)
    if they are all 1s, i.e.
    5c:c5:d4:7c:a3:44  v1-7030-psk  ac:a3:1e:b7:df:30  Associated   cWvSsEbM  0x1  Awake       (1,1,1,1,all,0)  166      212      0        6           866      780      44            43           2[0x3]     Thu Sep  3 15:46:16 2015  Thu Sep  3 15:46:16 2015  (0,0)             0          100/88
    then client has negotiated to use UAPSD
    things like this are not often documented (especially when the command is a debug command as this one is), if you have questions, just open more posts to the forum.
    regards
    -jeff
