Create a New AD Source
Update the Authentication Filter Query using
(&(userPrincipalName=%{Endpoint:Intune Email Address})(objectClass=user))
Enable Authorization under the MAC Auth Service, and add the new Source.
Update the role mapping policy like in the below screenshot, here we are checking if the userDn exist which will confirm user Account Exists ( we are using endpoint email to pull the data ) + we are verifying that the UAC is not 66050 ( Disabled
Here I am making an assumption that the email address is stored in userPrincipalName on AD, if not then you can update the filter query with the attribute which is storing the email address of the user
SANDEEP YADAV
Global Escalation Center, ACCP
Original Message:
Sent: Sep 22, 2021 08:17 PM
Subject: Intune & Endpoint repository
Would there be a way to look up in Active Directory by email address pulled from the Intune endpoint confirm if the user account is disabled. I added the attribute userAccountControl attribute to my source it seems to work followed this guide. Not sure how to rolemap this I would like to verify the user account email on our AD is not disabled. According to the guide it says when the account is disabled the userAccountControl is 66050.
https://community.arubanetworks.com/blogs/arunkumar1/2020/10/20/how-to-check-if-an-ad-account-is-disabled-in-clearpass-with-the-useraccountcontrol-attribute
Kelly L
Original Message:
Sent: Sep 20, 2021 08:18 PM
Yes as of now it's expected, unless there is an option of making an API call towards CPPM for deleting endpoints from MDM, endpoints will be deleted based on the CPPM cleanup intervals as CPPM will not have a track of as to which endpoints are deleted from the MDM server.
Hence, instead of deleting the endpoint, you can alter the attributes like is managed, or is compromised etc while leveraging those in policies.
SANDEEP YADAV
Original Message:
Sent: Sep 20, 2021 07:18 PM
HI,
When I remove a managed device from Intune I notice it does not remove it from endpoints is that normal behaver for the Intune extension? If so is there anything can be done to remove those devices?
Kelly L
