  • 1.  Intune extension upgrade
    Posted May 25, 2023 03:22 AM
    hi Airheads,
    if you have an old Intune extension version and you want to upgrade (for example from V3 to V6).
    Do you have to install old and re-install new extension ?
    cheers
    Pete
  • 2.  RE: Intune extension upgrade
    Posted May 25, 2023 12:32 PM
    sorry that should read "Do you have to un-install old version before installing new V6?"
  • 3.  RE: Intune extension upgrade
    Posted Jun 26, 2023 05:49 AM
    You can have multiple Intune Extensions running, so you don't need to uninstall the old one first. Just be aware that you can have only 1 extension using the same extension IP address (think about the HTTP Authentication Source if you use that), and replicating the same data through multiple paths may be a recipe for disaster so I would not recommend to run multiple versions of the extension on the same Intune Instance.
