Developer
IOT transport https telemetry error
  • 1.  IOT transport https telemetry error
    Posted Feb 02, 2024 10:03 AM
    I'm trying to config an AP-615 IoT to send out the ble data. The iothub endpoint works fine. But I added a https transport stream to a test website like https://webhook.site/mysiteid, and the output from 'show ap debug ble-relay iot-profile' shows that it's timeout etc. I put the faketoken and fakeid with the authentication.
    TransportContext                        : Failed
    Fail Reason                             : no response (timeout...etc)
    Last Data Update                        : 2024-02-01 13:12:24
    Last Send Time                          : 2024-02-01 13:12:29
    TransType                               : Https
    Any idea if I missed some config on the Transport stream?
    Thanks!
  • 2.  RE: IOT transport https telemetry error
    Posted Feb 03, 2024 06:49 AM
    Please share your iot profile configuration, Aruba SW version (ArubaOS oder Aruba Instand) and what type of data you would like to forward to you backend. Please also mention the type of connection and backend service you would like to use.
    BLE data forwarding (contrary to BLE telemetry) is only supported with using the connection type "telemetry-websocket" in the iot transport profile.  Based on the output you provided you configured telemetry-https.
    Jens
