We currently have an HP Procurve 2650 which was not configured by me and I have no idea how, but it's set to use a default gateway and ip routing. It has the default gateway set the same as the switch default vlan ip. We are currently replacing our older switches and I cannot achieve the same result with the newer HP 2920 Switch. Here's the current config from the 2650:
Running configuration:
; J4899B Configuration Editor; Created on release #H.10.31
hostname "CTHSIDF1 2650"
snmp-server contact
time timezone -480
time daylight-time-rule Continental-US-and-Canada
interface 50
name "GIGWAN"
exit
ip default-gateway 10.48.59.254
sntp server 192.43.244.18
ip routing
timesync sntp
sntp unicast
snmp-server community "sbcss" Operator
snmp-server community "bvusdsnmp"
vlan 1
name "DEFAULT_VLAN"
untagged 1-49
ip address 10.48.59.254 255.255.252.0
no untagged 50
exit
vlan 306
name "GIGWAN"
untagged 50
ip address 10.48.7.223 255.255.252.0
exit
ip route 0.0.0.0 0.0.0.0 10.48.7.254
password manager
password operator
Thanks for any help.
