For IPM reductions, priority 1 is applied before priority 2 and so on and so forth.
Josh
Original Message:
Sent: Feb 02, 2024 04:12 AM
Subject: IPM Priority
people around me answered so different with each other, It's so confusing.
the value of bigger one works first or the little one gonna work first..
Original Message:
Sent: Feb 02, 2024 04:10 AM
Hi, when I am reading an IPM content in InstantAP_8.10 user guide, I am confused with reduction step of which priority value is supposed to work first?
which band is supposed to be disabled under below cli configuration? 5Ghz or 6Ghz ?
(Instant AP) (config)# ipm
(Instant AP) (ipm) # ipm-power-reduction-step-prio ipm-step radio_6Ghz_disable priority 1
(Instant AP) (ipm) # ipm-power-reduction-step-prio ipm-step radio_5Ghz_disable priority 2
Thank you.
