SD-WAN
IPSEC between VGW and VHub Azure
  • 1.  IPSEC between VGW and VHub Azure
    Posted May 19, 2025 03:04 PM
    It's me first deployment of Virtual Gateway in Azure.
    We have several VNETS in Azure who are behind a VHUB.
    We cannot used the automated way in Aruba Central since we want to have control and naming conventions within the company.
    So we used the manual way. Our virtual gateway in Azure is up and running in central and my orchestrated tunnels between branch & Azure is working and established.
    So far so good.
    Now I want to propagate the branch subnets in Azure & Azure subnets to the branch.
    For this we want to use BGP between virtual gateway & Azure VHub.
    We followed the manual that you can find here: https://arubanetworking.hpe.com/techdocs/central/sd-branch-ref-docs/sd-wan-with-azure-public-cloud.pdf
    Hpe remove preview
    View this on Hpe >
    On page 92 we followed and executed the appendix 2 tutorial but our IPSec tunnel between Virtual Gateway and Azure VHUB doesn't come up.
    I see following error constantly popping up in the logs:
    May 19 20:27:52 2025  isakmpd[4525]: <103103> <4525> <WARN> |ike|   IKE SA Deletion: IKE2_delSa peer:X.X.X.X:4500 id:3993729299 errcode:ERR_IKESA_EXPIRED saflags:0x41000005 arflags:0x20
    May 19 20:28:34 2025  isakmpd[4525]: <103103> <4525> <WARN> |ike|   IKE SA Deletion: IKE2_delSa peer:X.X.X.X:4500 id:3993729300 errcode:ERR_IKESA_EXPIRED saflags:0x41000005 arflags:0x20
    Does anyone else get this thing working, if yes where did you pay attention and where must I look for?
    The people of Azure assured me that the IPSEC & IKE settings are correct.
    Thx in for your help. :)
