Wired Intelligent Edge
  • 1.  IPv6 VRF route leak not possible
    Posted Dec 12, 2019 05:30 AM
    Hey,
    I would like to configure a static IPv6 rout leak between two VRFs.
    With IPv4 I have done it like this:
    ip route [A.A.A.A/A] [vlanXYZ] [B.B.B.B] vrf [ABC]
    However, I can not configure a nexthop when trying the same with IPv6.
    Is this a bug or am I simply missig something? The documentation says both should be possible:
    [ip|ipv6] route <PREFIX> <SRC-VRF-LOCAL-IFACE>
    <SRC-VRF-NEXTHOP-IP> vrf <DST-VRF-NAME
    Running 10.04.0001 on a 8320.
  • 2.  RE: IPv6 VRF route leak not possible
    Posted Dec 12, 2019 04:23 PM
    I was able to configure like this.
    ipv6 route 2001:111::/64 2001:12::2 source 1/1/1 vrf ORANGE
    ipv6 route 2001:11::/64 2001:12::2 source 1/1/1 vrf ORANGE
    ipv6 route 2001:222::/64 2001:12::2 source 1/1/2 vrf BLUE
    ipv6 route 2001:22::/64 2001:12::2 source 1/1/2 vrf BLUE
    Can you ref to this document that Ive validated the same in 10.2. it should work with 10.4 as well. please let me know if any issues with 10.4
    https://community.arubanetworks.com/aruba/attachments/aruba/CampusSwitching/5878/1/InterVRF%20Route%20Leaking%20ArubaOS-CX.pdf
    Regards
    Reddy
  • 3.  RE: IPv6 VRF route leak not possible
    Posted Dec 13, 2019 05:41 AM
    That works for me too.
    I want to specify a nexthop IPv6 address as I did with IPv4, but that does not seem possible.
