SD-WAN
  • 1.  IPv6 with segmentation.
    Posted Jul 19, 2023 02:21 AM
    In bit of bind with this one, hope someone can advice further.
    Our organization has Aruba SDWAN as a service from service provider that include transport (undelay) links.
    In current legacy infra we already have IPv4 and IPv6 and Our organization is planning  to implement IPv6 along with IPv4 on SDWAN also.
    However, the response that we receive are Aruba SD-WAN will not support segmentation (VRF) with IPv6 and IPv4 together.
    Wanted to check if this is true? If yes, whether Aruba has plan to come up with some solution.
    Can we have any white paper for this.
  • 2.  RE: IPv6 with segmentation.
    Posted Jul 19, 2023 04:17 AM
    It may be best to work with your service provider, as 'Aruba SDWAN' can mean multiple things. You would need to know the exact product(s) used, and your service provider will know those details.
  • 3.  RE: IPv6 with segmentation.
    Posted Jul 19, 2023 04:38 AM
    Don't forget to ask which software version they currently support........
