Comware
  • 1.  IRF BETWEEN 5130 and 5140
    Posted Oct 20, 2023 10:43 AM
    I have a HPE 5130-24G-SFP-4SFP+ EI (JG933A) and i would like to know if i can do the IRF with a HPE FlexNetwork 5140 24G SFP con 8G + 4SFP+ EI ( JL826A). They are the same model with the same port but the oldest 5130 is no more produced.
    Thank you
  • 2.  RE: IRF BETWEEN 5130 and 5140
    Posted Oct 21, 2023 01:55 AM
    No you can't mix 5130 and 5140. It's not the same family.
    Best, Gorazd
    Gorazd Kikelj
    MVP Expert 2023
  • 3.  RE: IRF BETWEEN 5130 and 5140
    Posted Nov 22, 2023 12:07 PM
    thanks for this answer. I try to do this for 2 days...
    It's a shame to use the same name of protocole for, at the end, not to be suitable.
    thanks again.
    Best, Gwen
  • 4.  RE: IRF BETWEEN 5130 and 5140
    Posted Nov 23, 2023 06:46 AM
    Hi, from Aruba forum they confirm me is not possible. Thank you
