Comware
  • 1.  irf member isseu
    Posted Jul 02, 2017 03:15 PM
    Hi
    I have HP comware 5510 Two Switches. I configured Irf in both switch. when I configure irf member and priority there was a mistalke with member numbers in both switches. So now I wanted to remove the irf configuration but unfortunatly I couldn't delete the "irf member X priority XX" statment from the switch.
    I have tried with so many undo cmds. Finaly I was erase my statrup config. But the thing is same. The irf member priority statment is not deleting. any one has a experianced ?
  • 2.  RE: irf member isseu
    Posted Jul 06, 2017 04:12 AM
    Hello
    You should not undo this command but renumber it back to 1.
    Kind regards
  • 3.  RE: irf member isseu
    Posted Jan 30, 2025 06:43 PM
    irf member X renumber 1
