i am relatively new to networking topics and plan some bigger changes in our environment.
I home some of you experts can give me a thumb up/down to my plans.
We do have 2 * HP 5800 (was 3COM) as core switches + 6 * HP 2900AL48.
Current setup is:
- The 5800 are connected with 2 cables with LACP/trunk.
- Every 2900 is connected with 4 cables, 2 to both 5800. The 2 Cables/ports are trunked.
- Rapid Spanning tree is enabled on all devices. The 5800 have been given highest STP priority.
- There are also some servers connected to the 5800 switches (one cable to each 5800), each with an active passive bonding.
What i don't like:
- Even with RSTP enabled (Perhaps there is sth wrong) every STP change (because of changes, upgrade or unplanned downtime) affects the whole network.
- I want the servers to have active active bonding to higher bandwith (not, that we can really use it ;-) - i just like to get the most possible out of the setup)
Planned changes:
- physical topology stays the same
- enable IRF on the 2 5800 switches and stack them (2 * 40Gig cables/adapter are available)
- set up (irf)trunks over switch border on 5800er switches
- trunk all 4 cables/ports on the 2900 switches (connected with 2 to each switch)
- servers trunk active active
- disable STP on all switches
- enable loop detection on the 2900 switches for all ports
Expected improvements:
- 5800 switches bandwith from 20 Gbit to 40 (or is it even 80?) Gbit
- 2900 switches bandwith from 2Gbit to 4 Gbit
- Server bandwith from 1 to 2 / 10 to 20 Gbit
- No more spanning tree changes
- the 5800er switches are totally redundant, so only effect of a downtime would be, that half of the bandwith has gone, but with disabled STP no disruption of network traffic
- With 2900 downtime only this segment is affected - again no STP, so no disruption in network traffic
There is one exception:
Behind one of the 2900 switches there is another 2900 switch connected with fibre optics (2 trunked cables). (We can't change that and connect directly to core). Will i need STP here? In my understanding i do not, as there is only one (trunked) uplink, so loop detection to protect clients (or admins) from doing sth wrong is enough.
It's a long post, hot somebody will read it and give me some input, for errors or possible improvements.
Thank you very much!
Regards
