It seems that aruba is moving towards vsx as the main HA technology, is this correct ?
unfortunately at the moment its a bit confusing to choose a good & flexible core switching for medium sized businesses... The 8320 seems the best fit, as it supports vsx and has options for 1/10G SFP+ as well as 1/10G base-T and 40G. The downside is that these are not stackable ...so each 'peer' of the vsx is limited in this sense.
The 5406 is limited in other aspects such as type of 10G modules and supports only vsx ...
then there is the 8400 of course, but this is way too expensive and an overkill for medium sized campus LANs
the 8400 also seems to have limited tyoes of Line cards available (at least for the moment..)
There is still also option for HP IRF switching but it seems these are slowly being put to the side and most don't seem to fit the 'core' function ...also upgrading IRFs might be more difficult then vsx..
maybe HP/Aruba could provide us with an updated chart of core/distribution switch comparisions and way forward as the only ones I found are a bit old and not comprehensive....
