Comware
  • 1.  IRF3(Intelligent Resilient Framework 3) ?
    Posted Mar 29, 2014 07:12 AM
    Looking H3C´s for the latest upcoming HP products, I found this
    http://www.h3c.com.cn/Products___Technology/Products/Switches/Data_Center_Switch/S5800/5820V2-52QF/Home/Detail_Material_List/Feature/wap.html
    IRF3(Intelligent Resilient Framework 3). As google translation is not that great, can someone please explain the difference between IRF2 and IRF3?
  • 2.  RE: IRF3(Intelligent Resilient Framework 3) ?
    Posted Apr 01, 2014 11:02 AM
    Hi Michael
    IRF 3.0 will be vertical stacking. Stack a Switch with an other Switch-Model. It is like the Ciscos Nexus 7000 stacking with Nexus 2000 Portextenders.
    Would be a great thing for datacenters.
    br
    Manuel
  • 3.  RE: IRF3(Intelligent Resilient Framework 3) ?
    Posted Jun 06, 2014 08:23 AM
    What are the chances that this will include already existing models and not just future models?
    Im thinking of doing this between a 5120EI and 5820?
  • 4.  RE: IRF3(Intelligent Resilient Framework 3) ?
    Posted Jun 07, 2014 06:17 AM
    So it´s called Vertical IRF with "Controlling Bridge" and "Port Extender" devices.
    Btw, interesting there´s an HP S5120-HI mentioned.
  • 5.  RE: IRF3(Intelligent Resilient Framework 3) ?
    Posted Oct 21, 2014 05:49 AM
    As mentioned IRF 3 (as well called vertical-irf or VCF) is the evolution of the
    horizontally built IRF 2 into the vertical axis.
    We talk by now abot avery limited amount of devices that will actually support IRF 3.
    As controling bridge: 12500 series / 11900 series and the 5900th
    AS Port extender: 5500HI familie, 5700 familie and the 5900th.
    The usage model is either:
     - within the data center: any of the CB + either 5700th or 5900th or combinations as PE
    -  within campus envirinments: any of the CBs as building collector + combinations of 5500HI POE and the others as PE
    The differentiator to the nexus approach is: A PE in an IRF 3 is doing Layer 2! Therefore local switching.
    The feature is closly bound to the availability of Comware OS 7. So a close look into the availability of Comware 7 in above mentioned devides would make sense.
    Hope this helps
