Wired Intelligent Edge
Is 5412ZL Fan Tray Hot Swappable
  • 1.  Is 5412ZL Fan Tray Hot Swappable
    Posted Jul 10, 2012 11:44 AM
    Is 5412ZL Fan Tray Hot Swappable - I pulled one out hot on a lab switch and it did not cause and unexpected alerts but I am reluctant to do this on a switch with lots of users on it?
    #fan
  • 2.  RE: Is 5412ZL Fan Tray Hot Swappable
    Posted Jul 11, 2012 06:32 AM
    this is from Installation and Getting Started Guide for 5400zl switches:
    The fan tray is hot swappable. It can be removed and replaced without
    removing power from the switch. However, install the new fan tray
    immediately (within two minutes) after removing the old fan tray to avoid
    overheating and switch shutdown (within three minutes).
    BR,
    Jan
