Is it possible to select 2.4 GHz band and 5 GHz band?(APIN-0205)
  • 1.  Is it possible to select 2.4 GHz band and 5 GHz band?(APIN-0205)
    Posted Mar 30, 2017 09:38 PM
    Hi
    I have a question about selecting band by force.
    I'm emc testing enigineer & using apin-0205 for testing.
    I have to select 2.4 & 5 GHz band when testing wifi device that supports 2.4 ghz & 5 ghz.
    If i want to connect EUT to AP in 2.4 GHz, 5GHz Band of AP should be disable.
    Ex)
    EUT(2.4 GHz) <-----> Apin0205 (Only 2.4 GHz, 5 GHz should be diabled)
    EUT(5 GHz) <-----> Apin0205 (Only 5 GHz, 2.4 GHz should be diabled)
    Please give me some tip.
  • 2.  RE: Is it possible to select 2.4 GHz band and 5 GHz band?(APIN-0205)
    Posted Mar 30, 2017 10:02 PM
    In the SSID configuration under Advanced, you can say what band you want the SSID to broadcast..
