I've never implemented an SHL so no idea. The documented behavior would be in the User Guide if that exists.
Use a role mapping to assign a role based on your MAC address test...or just rely on the existing mapping that ClearPass already does to assign the vendor based on the OUI.
Original Message:
Sent: Oct 31, 2024 02:19 AM
Subject: is regex different in Static Host Groups?
So there is a difference between Regex for IP adresses and Regex for MAC-adresses in SHL? Do you by chance know if that is documented somewhere?
I am experimenting and thougt that SHL-names would be easyer to understand, than a Regex
Nicht_Gut
Original Message:
Sent: Oct 30, 2024 10:56 AM
Your initial description wasn't entirely clear.
Notice the difference in the example, no usage of ^ or $.
But, why bother with an SHL if you can accomplish the exact same outcome without the SHL?
Carson Hulcher, ACEX#110
Original Message:
Sent: Oct 30, 2024 10:45 AM
I am not using the device groups I use the static host Lists (Configuration>Identity>Static Host Lists) wich one can configure as IP or MAC
Nicht_Gut
Original Message:
Sent: Oct 30, 2024 09:57 AM
The device group RegEx is looking at IP addresses, not MAC addresses.
Original Message:
Sent: Oct 30, 2024 07:35 AM
Hello, I want to build a condition with Regex that gets trigged by a defined Vendor-MAC.
My current Regex solution is something like this: ^6C-C4-9F((-[0-9]|-[A-F])([0-9]|[A-F])){3}
The problem is that when I put this expression in a static host group it doesn't work but when I put it in the condition direktly it does.
Is Regex in a static host group different from regular Regex, if yes how? If not, has anyone a idea why the static host group doesn't work as a value for such a condition?
Nicht_Gut
