  • 1.  Is there an extension for Clearpass for Google Chromebooks like Intune or Jamf Pro?
    Posted 27 days ago
    Is there an extension similar to Intune or Jamf Pro that imports all the devices in Google Workspace into clearpass so we can authorize those devices?
    I see Google Sldap connector, but Im not looking to authenticate against google, just have something import all the macs of our chromebooks into clearpass so i can create a tips role or whatever and authorize them.
    thanks!
  • 2.  RE: Is there an extension for Clearpass for Google Chromebooks like Intune or Jamf Pro?
    Posted 26 days ago
    Hopefully someone has already done this. We have same situation. :)
  • 3.  RE: Is there an extension for Clearpass for Google Chromebooks like Intune or Jamf Pro?
    Posted 23 days ago
    The problem with importing mac addresses these days is that many devices start randomizing their mac addresses, so it may not even work.
    There may be an alternative route, where you onboard your chromebooks and then assign roles based on the certificate information. If you have an alternative way of onboarding, and can put some identifying information in the certificate (or use a specific issueing CA), you could assign roles based on that as well...
  • 4.  RE: Is there an extension for Clearpass for Google Chromebooks like Intune or Jamf Pro?
    Posted 22 days ago
    Onboarding is the better way which is the way I'm trying to push in my organization.  Google can apparently connect to an active directory certificate server so that's what I'm planning to do (but it's a pile of a lot of other stuff to do as well) - https://support.google.com/chrome/a/answer/11053129?hl=en
    Old instructions for the Endpoint Context Server is below but I wouldn't say it's the best, google often throws some weird stuff but in "general" it's better than loading them into the guest device database - which was the original way we had to do it.
    https://www.arubanetworks.com/techdocs/ClearPass/6.9/PolicyManager/Content/CPPM_UserGuide/Admin/EndpointContextServersAdd_GoogleAdminConsole.htm#top
