Wired Intelligent Edge
ISP Switch for Failover process?
  • 1.  ISP Switch for Failover process?
    Posted 10 days ago
    we have a 24 port switch Aruba to connect 2 ISPs to 2 firewalls. with 2 vlans, example:
    Vlan10
    Port 1-->ISP1
    Port2--->Firewall1
    Port3--->Firewall 2
    Vlan20
    Port10-->ISP2
    Port11-->Firewall1
    Port12--->Firewall2
    the problem i see on this is related to the switch, is a single power source switch....
    can you please advise about better options to interconnect these 2 firewalls to 2 ISP, is there any better topology?
    i was thinking on replace the switch, with a dual power source switch, but i wan to ask before if we have another stronger of more secure options in the market....
    thanks in advance...
  • 2.  RE: ISP Switch for Failover process?
    MVP GURU
    Posted 7 days ago
    This is typically how it's set up. Taking a switch as a shim to split the single ISP connections out to two or more firewalls. L2 separation is usually supported in most security policies. Using a stack with redundant switches is usually how I go about it. One ISP goes to one stack Member, and the 2nd ISP goes to the second stack member.
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022-2023
