I upgraded my cable modem to a Netgear CM700 and my Aruba 7005 controller can no longer obtain a public IP from my ISP. This was working on my old modem (a Motorola SB6120).
If I connect the same modem directly to a laptop, the laptop obtains a public IP OK. I reboot the modem on each attempt (controller & laptop attempts) and have rebooted the controller several times.
I followed https://community.arubanetworks.com/t5/Command-of-the-Day/COTD-Connect-your-Aruba-Controller-to-a-Cable-Modem/m-p/951/highlight/true#M64 to get it set up in the first place. Here's my relevant config:
vlan 100
interface vlan 100
ip address dhcp-client
interface gigabitethernet 0/0/0
switchport access vlan 100
interface vlan 100
ip nat outside
# Route clients out the internet connection.
ip default-gateway import dhcp
It appears to do with the new modem assigning itself a management IP (192.168.100.20). When I restart the modem, I get the following for about 30 seconds:
(Aruba7005) [mynode] (config) #show ip interface brief
Interface IP Address / IP Netmask Admin Protocol VRRP-IP
vlan 1 192.168.1.1 / 255.255.255.0 up up
vlan 100 192.168.100.20 / 255.255.255.0 up up
loopback unassigned / unassigned up up
DHCP is enabled on VLAN(s) 100
After the 30 seconds, it goes back to VLAN 100 being unassigned.
vlan 100 unassigned / unassigned up up
The logs seem to pinpoint the problem (ignored DHCPREQUEST due to unknown subnet) but I'm not sure what they mean or how to resolve the problem.
May 21 00:46:45 fpapps[3359]: <399838> <3663> <WARN> |fpapps| uplinkStateChangeCallback: intIfNum 1, ifType 3, event 6 usp 0/0/0
May 21 00:46:45 fpapps[3359]: <399838> <3663> <WARN> |fpapps| uplinkStateChangeCallback: intIfNum 220, ifType 9, event 3 usp 0/4/2
May 21 00:46:45 fpapps[3359]: <399838> <3663> <WARN> |fpapps| uplinkStateChangeCallback: intIfNum 220, ifType 9, event 6 usp 0/4/2
May 21 00:46:46 ntpwrap: getNtpSrvRouteAddr:304:connect() failed
May 21 00:46:51 fpapps[3359]: <399816> <3362> <ERRS> |fpapps| ipmRouterIfCreate:: Entering with index 3 ifnum 220 ip 192.168.100.20 Current switchIpVlanId : 1
May 21 00:46:51 fpapps[3359]: <399816> <3362> <ERRS> |fpapps| ipmRouterIfCreate:: Setting if_up to 1 within else...
May 21 00:47:01 fpapps[3359]: PAPI_Send: sendto DHCP Server failed: Connection refused Message Code 7007 Sequence Num is 9825
May 21 00:47:03 dhcpd: -> -> -> it is at dst_hmac_sha1_init : 1139
May 21 00:47:03 dhcpd: -> -> -> it is at dst_hmac_sha256_init : 1117
May 21 00:47:04 dhcpd[17922]: Vlan 100 entry already present
May 21 00:47:17 ntpwrap: ntpdPollingTimer:512 Upstream servers not reachable via local interface.
May 21 00:47:23 dhcpd: -> -> -> it is at dst_hmac_sha1_init : 1139
May 21 00:47:23 dhcpd: -> -> -> it is at dst_hmac_sha256_init : 1117
May 21 00:47:28 dhcpd[17999]: <299801> <17999> <DBUG> |dhcpd| DHCPREQUEST for 192.168.100.20 from 00:0b:86:a8:a5:88 via eth1: ignored (unknown subnet).
May 21 00:47:30 dhcpd[17999]: Vlan 100 delete from database as IP became 0
May 21 00:47:30 fpapps[3359]: <399838> <3369> <WARN> |fpapps| rtoCommonRouteDelete:1329: dest 0.0.0.0/0.0.0.0 not found in rto table
May 21 00:47:32 ntpwrap: getNtpSrvRouteAddr:304:connect() failed
May 21 00:47:32 ntpwrap: ntpdPollingTimer:512 Upstream servers not reachable via local interface.
May 21 00:47:43 dhcpd: -> -> -> it is at dst_hmac_sha1_init : 1139
May 21 00:47:43 dhcpd: -> -> -> it is at dst_hmac_sha256_init : 1117
May 21 00:47:47 ntpwrap: getNtpSrvRouteAddr:304:connect() failed
