>Assuming the device is being recognized properly and the connection to the network is correct, then there's nothing on the network side that should be preventing the device from requesting or receiving DHCP.
Agreed.
Phones use lldp to detect presence of tagged voice vlan on switch port switch to it and of they go. As I said, problem is cppm drops them into voice vlan , we can see its there but sh lldp inf r shows phone doesnt have an IP
> I'd recommend getting a packet capture showing what is going on between the phone and the network once you've moved to the production network.
Yeah might come to that.
>The closest I've seen to this is some devices that like to fire off a DHCP request as soon as they have power/link (but not necessarily a network connection) and then never again.
Yeah seen that as well. Guess forcing a CoA reauth is slightly different in that the phone is up and breathing at that point
A
Original Message:
Sent: 6/12/2025 1:29:00 PM
Subject: RE: Issue witgh polycom phones and. authentication
Assuming the device is being recognized properly and the connection to the network is correct, then there's nothing on the network side that should be preventing the device from requesting or receiving DHCP. I'd recommend getting a packet capture showing what is going on between the phone and the network once you've moved to the production network.
Carson Hulcher, ACEX#110
Original Message:
Sent: Jun 12, 2025 11:50 AM
Subject: Issue witgh polycom phones and. authentication
Got an issue with Polycom phones, and authentication in that phones dont pick up an ip when moved from staging area to live area
1). Polycom C60 and CCX505 phones running latest and greatest 9.1.x firmware
2). Aruba OS-S 2930 switches running WC.16.11.21 firmware
3). Clearpass 6.11.10 providing DUR to drop phone into named tagged voice valn
Phones identifed by custom clearpass fingerprint .
Enforcement policy pshes dur to switch
Plug phone in on staging point switch to upgrade firmware register and configure phone.
Check phone works.
Unplug phone and take to. destination and plug into another switch
clearpass sends mac-auth from that switch/port, identifies phone and. sends DUR
What should happen is
cppm places devcie in tagged voice vlan
phone uses lldp to identify tagged voice vlan, move to it and get an ip address
but .....
sh port-access client shows mac address of phone in tagged voice vlan
sh lldp inf r shows switch can see phone model
phone doesnt get an ip address, can sit there for hours ( reauth time. 1 hour). DHCP ip lease is 2 days
Back at clearpass, if i force a port bounce CoA ( local one that holds port down for 30 secs ) phone requsts and. obtains ip and off it goes
Would have thought unplugging phone and walking. to destination would have done the same thing
Dont want to enable profiling on the auth and force a drop after every auth as that would be dropping interface for 12 secs every hour
Any thoughts ?
A
