Developer
  • 1.  Issue with Aruba API Authentication: Access Denied Error
    Posted Jan 27, 2025 02:27 AM
    Edited by EFishel Apr 08, 2025 04:26 PM
    Hi everyone
    I'm working with the Aruba Networks API to automate some network configurations, but I'm running into an issue with the authentication process. When I try to authenticate using the API key, I keep getting the following error:
    Access Denied: Invalid API Key or Permissions
    I've double-checked the API key and made sure it's assigned the correct permissions, but I'm still getting the same error. Has anyone else run into this problem or have any suggestions on what I might be missing?
    Thanks in advance!
    https://www.concretesrichmondva.com/
  • 2.  RE: Issue with Aruba API Authentication: Access Denied Error
    Posted Jan 27, 2025 11:08 AM
    Hi Dylan,
    Could you clarify which HPE Aruba Networking product you are trying to create API token for ?
    You can also check out our Developer Hub for detailed automation guides.
    Thanks & Regards,
    Karthik Satheesh Kumar
  • 3.  RE: Issue with Aruba API Authentication: Access Denied Error
    Posted Jan 27, 2025 06:42 PM
    Can you give us more information on which API you are trying to access so we can help you. Thanks
    Daniel Ruiz
    If you have urgent issues, always contact your Aruba partner, distributor, or Aruba TAC Support.
    Check https://www.arubanetworks.com/support-services/contact-support/ for how to contact Aruba TAC.
  • 4.  RE: Issue with Aruba API Authentication: Access Denied Error
    Posted Jan 29, 2025 11:50 AM
    Hi Dylan.
    On Aruba Github you will find libraries for many API tasks so you don't need to use raw API calls. As you didn't mention what API and platform you are using, answers will be very generic.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
