Thank you for checking. I've brought it again to their attention.
Original Message:
Sent: Feb 20, 2025 06:07 AM
Subject: Issue with Captive-Portal using Aruba Cloud-Guest - Tunnelled SSID
This is how it looks like for me:
(cic-mg01-9114) #show aaa authentication-server allAuth Server Table-----------------Name Type FQDN IP addr AuthPort AcctPort Status Requests---- ---- ---- ------- -------- -------- ------ --------Internal Local n/a 52.36.146.215 n/a n/a Enabled 0AS1_#cloud_auth#_ Radius naw1.cloudguest.central.arubanetworks.com 54.185.82.247 2083(radsec) 2083(radsec) Enabled 170AS2_#cloud_auth#_ Radius naw1-elb.cloudguest.central.arubanetworks.com 44.234.219.72 443(radsec) 443(radsec) Enabled 0cppm.lab.hpearuba.net Radius cppm.lab.hpearuba.net 10.12.99.40 1812 1813 Enabled 11151cppm2.lab.hpearuba.net Radius cppm2.lab.hpearuba.net 10.12.99.42 1812 1813 Enabled 0cppm-tacacs Tacacs n/a 10.12.99.40 49 n/a Enabled 0cppm1-tacacs Tacacs n/a 10.12.99.41 49 n/a Enabled 3cppm2-tacacs Tacacs n/a 10.12.99.42 49 n/a Enabled 0(cic-mg01-9114) #show aaa authentication-server radius AS1_#cloud_auth#_RADIUS Server "AS1_#cloud_auth#_"---------------------------------Parameter Value--------- -----Enable IPv6 DisabledHost naw1.cloudguest.central.arubanetworks.comKey ********CPPM credentials N/AAuth Port 1812Acct Port 1813RadSec Port 2083Retransmits 3Timeout 20 secNAS ID 63404eb5-d488-49b4-a1c3-9f0beafbc4f5NAS IP N/ANAS IPv6 N/ASource Interface N/AUse MD5 DisabledUse IP address for calling station ID DisabledMode EnabledLowercase MAC addresses DisabledMAC address delimiter noneService-type of FRAMED-USER DisabledRadSec EnabledRadSec Trusted CA Name N/ARadSec Server Cert Name N/ARadSec Client Cert N/Acalled-station-id macaddr colon disableAccess-Request Modifier N/AAccounting-Request Modifier N/AMessage-Authenticator required in Access-Accept/Reject/Challenge NoRadsec EST Cert Profile N/A
RadSec is/should be enabled.
Original Message:
Sent: Feb 18, 2025 04:05 PM
If you would please, bring this directly to the attention of the TAC engineer and escalate if necessary.
Carson Hulcher, ACEX#110
Original Message:
Sent: Feb 18, 2025 12:15 PM
This was something that I mentioned to TAC, because I remember when I was looking at the FW logs before the issue started, I saw a lot of requests from the GWs to the cloud-servers on port 2083. The FW logs after the issue started, I'm now seeing requests to from the same GW to cloud-servers, on 1812 and 1813, none on 2083, which I found odd.
There was no change that happened on our side, that could have caused the GWs to stop reauthenticating on 2083, and now attempt on 1812, 1813. Based on this, I feel like this this setting below:
The radius cloud-auth 1 settings does say "RADSEC" disabled.
I remember seeing TAC looked at this setting specifically but didn't say anything about it, so I figured that is just the way it is supposed to be configured.
Original Message:
Sent: Feb 14, 2025 10:56 AM
Both of the Cloud Guest auth servers should be connecting with RadSec, either over port 2083 or 443. Since your output is showing native RADIUS on UDP 1812/1813, that is incorrect. As to why that is happening, no idea, but point that out to your TAC engineer and go from there.
Original Message:
Sent: Feb 05, 2025 04:27 PM
We've been having issues for a while now our new Aruba Wi-Fi system using the Aruba Cloud-Guest captive portal. I have a TAC ticket opened for almost two weeks now, and they cannot seem to give us an explanation on the issue. They keep on asking to recreate the issue, gather logs, which I have done and sent them, but still no answer on what is issue is or where to even start looking. We've recently moved from all Cisco and Meraki APs, and we've never had any of these issues, or at least they've helped us solve it in way less time.
I have an idea on what could it be based on what I'm seeing, but I do not fully understand how the Cloud-Guest authentication works. I need some insight on what could be causing these issues.
Issues / Symptoms:
When users connect to the SSID, two things can either happen or happen at the same time:
- First Issue - Users get "cannot connect to network". It will eventually connect after waiting for 2-5 minutes. They will get an IP from DHCP, then captive-portal shows up. *This relates to the "MAC Authentication" errors / timeouts we see on the Aruba Central Logs.
- Second Issue - Users get the captive-portal prompt, to accept "terms and conditions", once they tick the checkbox and click "accept" button, they get a "Login Error". Again, it will eventually connect after waiting for 2-5 minutes. They are now connected to the internet. *This relates to the "Captive-Portal" errors / timeouts we see on the Aruba Central Logs.
Note: The above does not happen all the time, its very random. This is why its hard to recreate the issue. And we do not get a lot of complaints from users, because it will eventually connect.
Here's some background of our environment:
2 x Aruba 9114 GWs Mobility Gateways - Auto-Clustered
Aruba AP-635s
SSID Configured as Tunnel-Mode to GW-Cluster
SSID Security is Captive-Portal using Aruba Cloud-Guest. MAC-Caching is Enabled.
See diagram:
- User device connects to the SSID.
- User is then tunneled to Guest-Internet VLAN(500) to the 9114 GW.
- User traffic will hit the FW, then out to the internet.
Additional observations:
- When we turn off MAC-Caching on the Cloud-Guest settings, issue #1 completely goes away. My assumption is when its off, the Aruba Gateways does not have to send MAC authentication requests to the Cloud-Servers.
- Changing the SSID Security to PSK, completely removes all issues. This issue is related to using captive-portal on Cloud-Guest 100%.
A bit more detail on what I'm seeing:
- When using Captive-Portal and Cloud-Guest, the Aruba Central configures the Gateways with two Authentication-Server Groups, AS1 and AS2, each tied to the URL below.
- Looking at the error logs on the GWs, when a user connects to the Wi-Fi and encounters one of the issues above, I see a log entry "authentication-server timeout servergroup=AS1". It will eventually connect. Once the user is connected, if you check "show user mac 00:00:00:00:00:00", it will then tell you that the user is authenticated on what server-group, either AS1 or AS2. All of the connected users are authenticated on AS2. Nothing is authenticated on AS1.
- Running the command "show aaa authentication-server all" shows below (Note the Requests Column):
Now the questions and assumptions:
- I think the reason why the issue is intermittent and will connect eventually, is because of the two auth servers. If a user authenticating, either by MAC or by Web, it gets assigned to the first set of servers (AS1), it fails or times out. It will then get rolled over to the second set of servers(AS2), then it works.
- This can explain why all connected users are showing as authenticated on AS2.
- All the auth-server requests are all going to AS2, based on the requests count.
- Why is this happening? Both of the URLs are added to our FW Whitelist, as well as the individual IPs those URLs are assigned to (nslookup).
- We have TCP 2083,443 and just added UDP 1812,1813 allowed for above. We do not see any "denies" on our FW for any traffic coming from our GWs.
- Now its possible that I'm not understanding how the Aruba Cloud-Guest, RADIUS, MAC-Auth works, so it could be likely that I'm putting my focus on the wrong thing. Maybe the error logs about auth-server timeouts to AS1 is nothing to get worried about? I've asked TAC multiple times to explain to me what these errors mean, or how the Cloud-guest authentication works, but all they say is "add more debugging and captures and we will get back to you".
Sorry for the lengthy post. I hope what I've described makes sense and someone can chime in on what the issue is, and where I can start looking. I can share some outputs from my APs and GWs if you need to have a look at what we have.
Thank you.
Vascar
