The mac-address table only shows one MAC for vlan 115 which is the switches uplink port to the router, 1/4/1:
VM_switch# show mac-address-table vlan 115
MAC age-time : 300 seconds
Number of MAC addresses : 1
MAC Address VLAN Type Port
xx:xx:xx:xx:xx:xx 115 dynamic 1/4/1
The output for show interface lag1:
VM_switch# show interface lag1
Aggregate lag1 is up
Admin state is up
Description : VM
MAC Address : xx:xx:xx:xx:xx:xx
Aggregated-interfaces : 1/4/2 1/4/3 1/4/4 1/4/5
Aggregation-key : 1
Speed : 100000 Mb/s
qos trust none
VLAN Mode: native-untagged
Native VLAN: 1
Allowed VLAN List: 3,19,37,40,59,115,301-302
L3 Counters: Rx Disabled, Tx Disabled
Statistic RX TX Total
Packets 373968743207 228661979996 602630723203
Unicast 373857458490 228234080839 602091539329
Multicast 58189431 61525971 119715402
Broadcast 53095286 366373186 419468472
Bytes 408891577622067 57852373612636 466743951234703
Jumbos 148995934589 15914555006 164910489595
Dropped 0 0 0
Pause Frames 0 0 0
Errors 50 0 50
CRC/FCS 0 n/a 0
Collision n/a 0 0
Runts 0 n/a 0
Giants 50 n/a 50
The config for the interfaces is below:
VM_switch# show int 1/4/2-1/4/5
Interface 1/4/2 is up
Admin state is up
Link state: up for 1 year (since Sat Dec 23 01:22:20 MST 2023)
Link transitions: 1
Description: VM
Persona:
Hardware: Ethernet, MAC Address: xx:xx:xx:xx:xx:xx
MTU 1500
Type 25G-SR / 25G SFP28 SR
Full-duplex
qos trust none
Speed 25000 Mb/s
Auto-negotiation is off
Flow-control: off
Error-control: RS-FEC
Rate collection interval: 300 seconds
Rate RX TX Total (RX+TX)
Mbits / sec 26.97 1.88 28.85
KPkts / sec 3.32 1.27 4.59
Unicast 3.32 1.27 4.59
Multicast 0.00 0.00 0.00
Broadcast 0.00 0.00 0.00
Utilization % 0.11 0.00 0.11
Packets 109614066385 57316769592 166930835977
Unicast 109598506326 57307944515 166906450841
Multicast 4315191 8641236 12956427
Broadcast 11244868 183841 11428709
Bytes 117084171112624 17104737709217 134188908821841
Jumbos 42090387677 5768230616 47858618293
Dropped 0 0 0
Pause Frames 0 0 0
Errors 14 0 14
CRC/FCS 0 n/a 0
Collision n/a 0 0
Runts 0 n/a 0
Giants 14 n/a 14
Interface 1/4/3 is up
Admin state is up
Link transitions: 1
Description: VM
Persona:
MTU 1500
Full-duplex
qos trust none
Speed 25000 Mb/s
Flow-control: off
Mbits / sec 15.24 1.67 16.91
KPkts / sec 1.34 1.30 2.64
Unicast 1.34 1.30 2.64
Utilization % 0.06 0.00 0.06
Packets 77339333733 59564321408 136903655141
Unicast 77296030166 59403011394 136699041560
Multicast 12643285 19988985 32632270
Broadcast 30660282 141321029 171981311
Bytes 87315413563819 13931814855663 101247228419482
Jumbos 32600562653 3427605651 36028168304
Dropped 0 0 0
Pause Frames 0 0 0
Errors 5 0 5
CRC/FCS 0 n/a 0
Collision n/a 0 0
Runts 0 n/a 0
Giants 5 n/a 5
Interface 1/4/4 is up
Admin state is up
Link transitions: 1
Description: VM
Persona:
MTU 1500
Full-duplex
qos trust none
Speed 25000 Mb/s
Flow-control: off
Mbits / sec 16.86 1.65 18.51
KPkts / sec 2.52 1.48 4.00
Unicast 2.52 1.48 4.00
Utilization % 0.07 0.00 0.07
Packets 109319576543 58428793853 167748370396
Unicast 109307766075 58181513294 167489279369
Multicast 7415567 27277793 34693360
Broadcast 4394901 220002766 224397667
Bytes 116482557881301 13214375796270 129696933677571
Jumbos 41125724010 3027063929 44152787939
Dropped 0 0 0
Pause Frames 0 0 0
Errors 30 0 30
CRC/FCS 0 n/a 0
Collision n/a 0 0
Runts 0 n/a 0
Giants 30 n/a 30
Interface 1/4/5 is up
Admin state is up
Link transitions: 1
Description: VM
Persona:
MTU 1500
Full-duplex
qos trust none
Speed 25000 Mb/s
Flow-control: off
Mbits / sec 9.69 2.27 11.96
KPkts / sec 0.89 1.34 2.23
Unicast 0.89 1.34 2.23
Utilization % 0.04 0.00 0.04
Packets 77698083876 53353597845 131051681721
Unicast 77657472557 53343111983 131000584540
Multicast 33815921 5618428 39434349
Broadcast 6795398 4867434 11662832
Bytes 88011996088502 13601699796424 101613695884926
Jumbos 33180352779 3691690396 36872043175
Dropped 0 0 0
Pause Frames 0 0 0
Errors 1 0 1
CRC/FCS 0 n/a 0
Collision n/a 0 0
Runts 0 n/a 0
Giants 1 n/a 1
Original Message:
Sent: Mar 05, 2025 04:40 AM
Subject: Issue with VLAN in LAG
Did you check the MAC address table?
Please also check the status of LAG1.
show interface lag 1
Can you also share the physical interface configuration where LAG1 is used?
Willem Bargeman
Systems Engineer Aruba
ACEX #125
Original Message:
Sent: Mar 04, 2025 09:22 AM
I've got an established lag interface that feeds a VM infrastructure. We're needing to add a new network, vlan 115, to the lag but can't seem to get it to work. The vlan has been established on the switch and it's been added to the uplink:
vlan 115
description PACS
interface 1/4/1
description Uplink
no shutdown
no routing
vlan trunk native 317
vlan trunk allowed 3,16,19,37,59,115,301-302,317,500
It's also been added to the lag interface:
interface lag 1
description VM LAG
no shutdown
no routing
vlan trunk native 1
vlan trunk allowed 3,19,37,40,59,115,301-302
All the other vlans that are currently attached work without issue. I added vlan 115 to a separate interface for testing purposes and the network is working as intended but when using the lag interface connectivity on that network does not work. Any advice on troubleshooting this issue would be appreciated.
