SD-WAN
issues with uploading SDN application from SDN controller GUI
  • 1.  issues with uploading SDN application from SDN controller GUI
    Posted Dec 04, 2014 02:44 PM
    Hi SDN team,
    I followed the instruction from "SDN Controller Programming Guide" and generated the hm (health monitor) application. It builds successfully, but when I try to upload it using the SDN controller GUI, I got the following error. Any idea what's wrong? Thanks!
    hm-api-1.0.0-SNAPSHOT.jar is not signed or has been tampered with
    Server Error – 400: Bad Request
    URL: rs/apps
    View ID: apps
    Type: error
  • 2.  RE: issues with uploading SDN application from SDN controller GUI
    Posted Dec 05, 2014 12:44 PM
    Thank you for contacting the HP SDN Forum. Have you tried running the controller without the Jar-Signing Validation?
    If not, here are the instructions from the HP VAN SDN Controller 2.3 Administrator Guide, page 68-69:
    5.8.2 Running the SDN Controller Without Jar-Signing Validation
    The SDN Controller enforces jar-signing validation by default. For an experimental/development
    environment where unsigned applications need to be deployed, jar-signing validation can be
    turned off altogether:
    1.  Use the following command to stop the SDN Controller:
    sudo service sdnc stop
    2.  Modify the/opt/sdn/virgo/bin/dmk.shscript to add the following option to the list of
    JMX_OPTS
    -Dsdn.signedJar=none
    For example:
    cd $KERNEL_HOME; exec $JAVA_EXECUTABLE \
    $JAVA_OPTS \
    $DEBUG_OPTS \
    $JMX_OPTS \
    -XX:+HeapDumpOnOutOfMemoryError \
    -XX:ErrorFile=$KERNEL_HOME/serviceability/error.log \
    -XX:HeapDumpPath=$KERNEL_HOME/serviceability/heap_dump.hprof \
    -Dsdn.signedJar=none \
    -Djava.security.auth.login.config=$AUTH_LOGIN \
    -Dorg.eclipse.virgo.kernel.authentication.file=$AUTH_FILE \
    3. Start the SDN Controller:
    sudo service sdnc start
    To enable jar-signing validation, remove the line containing the
    -Dsdn.signedJar=noneoption
    from the /opt/sdn/virgo/bin/dmk.sh script and restart the controller.
    Best Regards,
    Carlos
    CoE SDN Team,
  • 3.  RE: issues with uploading SDN application from SDN controller GUI
    Posted Dec 05, 2014 03:05 PM
    Problem solved. Thanks SDN team!
