Comware
  • 1.  JG898A 5700 bootrom
    Posted Oct 16, 2023 06:48 PM
    I am trying t see if there is an updated bootrom for HP 5700 (JG898A) switches. This is where I am searching and it doesn't show anything available. https://asp.arubanetworks.com/
    Does anyone know if available? The current software upgrade P06 requires bootrom Rev. 157 and we have Rev. 147
    <DBNET-10G - JG898A>display version
    HPE Comware Software, Version 7.1.045, Release 2422P02
    Copyright (c) 2010-2016 Hewlett Packard Enterprise Development LP
    HPE FF 5700-32XGT-8XG-2QSFP+ Switch uptime is 0 weeks, 2 days, 18 hours, 40 minutes
    Last reboot reason : USER reboot
    Boot image: flash:/5700-cmw710-boot-r2422p02.bin
    Boot image version: 7.1.045, Release 2422P02
      Compiled Aug 05 2016 16:00:00
    System image: flash:/5700-cmw710-system-r2422p02.bin
    System image version: 7.1.045, Release 2422P02
    Slot 5:
    Uptime is 0 weeks,2 days,18 hours,40 minutes
    FF 5700-32XGT-8XG-2QSFP+ Switch with 2 Processors
    BOARD TYPE:         FF 5700-32XGT-8XG-2QSFP+ Switch
    DRAM:               2048M bytes
    FLASH:              512M bytes
    PCB 1 Version:      VER.B
    Bootrom Version:    147
    CPLD 1 Version:     004
    CPLD 2 Version:     003
    Release Version:    HPE FF 5700-32XGT-8XG-2QSFP+ Switch-2422P02
    Patch Version  :    None
    Reboot Cause  :     UserReboot
    [SubSlot 0] 32XGT+8SFP Plus+2QSFP Plus
    Slot 6:
    Uptime is 0 weeks,2 days,17 hours,23 minutes
    DRAM:               2048M bytes
    FLASH:              512M bytes
    CPLD 1 Version:     004
    CPLD 2 Version:     003
    Reboot Cause  :     AutoUpdateReboot
    Slot 7:
    Uptime is 0 weeks,2 days,17 hours,19 minutes
    DRAM:               2048M bytes
    FLASH:              512M bytes
    CPLD 1 Version:     004
    CPLD 2 Version:     003
    Reboot Cause  :     IRFMergeReboot
    Slot 8:
    DRAM:               2048M bytes
    FLASH:              512M bytes
    CPLD 1 Version:     004
    CPLD 2 Version:     003
    Thanks In Advance!
  • 2.  RE: JG898A 5700 bootrom
    Posted Oct 17, 2023 03:11 AM
    Hi, if you download and use the .IPE file it includes the boot file as well as the system file. The release notes have the full details of this:
    As long as the upgrade path is compatible (see release notes) then you will update both components as required. I have never independently upgraded a bootrom image in a decade of using comware.
  • 3.  RE: JG898A 5700 bootrom
    Posted Oct 18, 2023 02:57 PM
    Hi Ian and Thanks for Responding. As I look at this doc https://support.hpe.com/hpesc/public/docDisplay?docId=a00005966en_us, the confusing part is it says version 156 or higher. So my assumption was I needed 156 before I could upgrade the code. I want to put the latest on these switches. I am also assuming based on the date that P61 is latest vs P06.  (why wouldn't it be P06.1 or P07?)
    Item
    Specifications
    Product family
    5700 Series
    Hardware platform
    HPE 5700-40XG-2QSFP+ JG896A
    HPE 5700-40XG-2QSFP+ TAA JG897A
    HPE 5700-32XGT-8XG-2QSFP+ JG898A
    HPE 5700-32XGT-8XG-2QSFP+ TAA JG899A
    HPE 5700-48G-4XG-2QSFP+ JG894A
    HPE 5700-48G-4XG-2QSFP+ TAA JG895A
    Minimum memory
    requirements
    2 GB
    Minimum Flash requirements
    512 M
    Boot ROM version
  • 4.  RE: JG898A 5700 bootrom
    Posted Oct 19, 2023 03:06 AM
    Hi, there is something strange about comware releases in the last year. For the 5900 which I have a lot of there was nothing since about 2018 then a release more recently. I read this as they were no longer developing but then had a serious security fix. It looks the same for your 5700:
    5700_7.10.R2432P61     Released on Mar 6, 2023
    5700_7.10.R2432P06     Released on Jul 2, 2018
    I found a useful paragraph that clarifies that there is a boot ROM file and a boot bin file. It does say they all come in the IPE file. I think this is why I've never upgraded the boot ROM before. In reality I have, I just didn't watch the screen for the upgrades as it takes so long and for some upgrades it will have sorted the ROM image too.
    https://www.arubanetworks.com/techdocs/comware/RN/HPE5700CMW710R2432P61RN.pdf
    This is further confirmed with the text:
    The system automatically checks the compatibility of the Boot ROM image and the boot and system
    images during the reboot. If you are prompted that the Boot ROM image in the upgrade image file is
    different than the current Boot ROM image, upgrade both the basic and extended sections of the
    Boot ROM image for compatibility. If you choose to not upgrade the Boot ROM image, the system
    will ask for an upgrade at the next reboot performed by powering on the switch or rebooting from the
    CLI (promptly or as scheduled). If you fail to make any choice in the required time, the system
    upgrades the entire Boot ROM image.
    So in short, if you upgrade using the IPE file and don't interrupt it will automatically upgrade the boot ROM.
    Latest version is P61 with the release notes here:
  • 5.  RE: JG898A 5700 bootrom
    Posted Jan 04, 2024 12:20 AM
    Good Info Ian, Thanks!
