Comware
JG963A PSE/PoE Firmware missing
  • 1.  JG963A PSE/PoE Firmware missing
    Posted Apr 15, 2023 10:20 AM
    I just updated to the latest FW 7.1.070 Release 3507P09.
    On startup I receive a log message like this:
    Critical:  Power 2 failed.
    And I receive lots of log messages like this:
    Alert:  Trap <pethPsePortOnOffNotification>: PSE 7, IfIndex XY, Detection Status 3.
    The device is operating ok.  And I found a link that is pretty old but mentions an update for the PoE of the switch (https://support.hpe.com/hpesc/public/docDisplay?sp4ts.oid=7399420&docLocale=en_US&docId=emr_na-c04756147) .  The link inside that post is also old, does not work anymore and I believe that there is a newer version.
    And I can see that the PoE FW can be updated.  But where do I get this PSE/PoE firmware from?  Cannot find it.  Any hints?
    Thanks a lot & cheers!
    -lutz
  • 2.  RE: JG963A PSE/PoE Firmware missing
    Posted Dec 08, 2024 08:37 PM
    Ok, I know this is a necro, but I am about to do this upgrade to a few switches, is there an issue ?
