  • 1.  JL184A - IAP-205-RW
    Posted Aug 31, 2016 11:23 AM
    Will a HP JL184A work in the same cluster as an Aruba IAP-205; and do they run the same firmware?
  • 2.  RE: JL184A - IAP-205-RW
    Posted Aug 31, 2016 11:25 AM
    The short answer is no, because they run different firmware...
  • 3.  RE: JL184A - IAP-205-RW
    Posted Aug 31, 2016 11:27 AM
    Ahh, thanks Colin,
    Can they be converted with Aruba firmware or would it be the same problem as converting a Dell one?
