I am trying to execute a job command, which should copy the backup config file to the TFTP server, but the command does not do anything on the specific set time. When I run the command manually, the TFTP server gets the backup configs file, but the job scheduler does not work. Does anyone have this issue before? How did you manage to solve it?
The switch details are:
HP J9851A Switch 5412Rzl2
Software revision KB.16.02.0013
and the command which I am trying to run is:
job "backup_conf" at 03:00 on Sun-Sat config-save "copy run tftp <IP> filename.txt"
