  • 1.  Joining IAP 104 to IAP 315 cluster
    Posted Nov 14, 2016 03:16 PM
    Hi all,
    We created a new IAP 315 Instant cluster with 6 access points. All is well there. The issue we are running into when trying to join older IAP 104’s to the new IAP 315 Instant network in a “class mismatch”. The IAP 315’s are on the 6.5.0.0-4.3.0.0_56428 Hercules firmware whereas the 104’s are on 6.4.4.6-4.2.4.0_55341 Orion. From what I understand the firmware version numbers have the match, so we need a 6.5.0.0-4.3.0.0_56428 Orion firmware. I could not find this firmware on the Aruba support site, the latest ones are the 6.4 series, there is no 6.5 on there at all. Any suggestions on how to proceed?
  • 2.  RE: Joining IAP 104 to IAP 315 cluster
    Posted Nov 14, 2016 03:25 PM
    Starting from Instant 6.5.0.0-4.3.0.0, the following 802.11n IAPs are not supported:
    IAP-104 and IAP-105
    RAP-3WN and RAP-3WNP
    IAP-134 and IAP-135
    IAP-175
    Attached Release Notes of 6.5.0.0-4.3.0.0
    Attachment(s)
  • 3.  RE: Joining IAP 104 to IAP 315 cluster
    Posted Nov 14, 2016 03:32 PM
    Hi Vincent,
    That is unfortunate. Since the 315's are absolutely brand new to the market we did not know what version of firmware it would come it (and that it would be incompatible with IAP 104). Do you have options?
    (1) Can we downgrade the firmware on 315 to a matching version that will work with 104?
    (2) Can the 104s's form a separate cluster on the same subnet as the 315s?
    Jaiwant.
  • 4.  RE: Joining IAP 104 to IAP 315 cluster
    Posted Nov 14, 2016 03:45 PM
    Hi Jaiwant,
    The minimum software version supported by IAP 315 is 4.3.0.0 as you can find it in the data sheet below.
    http://www.arubanetworks.com/assets/ds/DS_AP310Series.pdf
    So, we cannot downgrade the 315s below 4.3 or upgrade 104s to 4.3. You need to use them on separate clusters.
  • 5.  RE: Joining IAP 104 to IAP 315 cluster
    Posted Nov 14, 2016 03:51 PM
    Ok .. thanks. Can we create separate clusters (one for 104 and one for 315) on the same subnet?
  • 6.  RE: Joining IAP 104 to IAP 315 cluster
    Posted Nov 14, 2016 04:02 PM
    No, we cannot. We need them on separate subnets / VLANs to create separate cluster.
