Comware
  • 1.  jumbo frame
    Posted Feb 10, 2005 09:55 AM
    Can you tell me which module is required to support jumbo frame in a 9300 procuver swithc?
  • 2.  RE: jumbo frame
    Posted Feb 10, 2005 10:26 AM
    Hi, mai !
    You can use jumbo frame (MTU up to 14336)on EP chassis devices ONLY.
    HP Procurve 9300 chassis devices are either EP or Standard (non-EP) depending on whether the management module is an EP or Standard (non-EP).
    You cannot use EP modules and non-EP modules in the same chassis.
    BR,
    Dmitry.
  • 3.  RE: jumbo frame
    Posted Feb 10, 2005 10:42 AM
    Thank you.
    Do you have the product number for the EP module? or a URL pointing to the product info?
    Thank you
    Mai
  • 4.  RE: jumbo frame
    Posted Feb 10, 2005 11:01 AM
