Dear Community,
I would like to ask some clarificiations/confirmations about the Reauthentication Interval setting inside the MAC authentication profile.
-Does it well correct that we need to activate Reauthentication on the screenshot below to have Max Authentication failures and Reauthentication Interval starting to take effect?
-Reauthentication Interval, does it well mean that after first attempt, the client needs to wait 86400 to try to authenticate again?
-If Max Authentication failures is set to 0, does it mean that the client is blacklisted if first attempt is rejected? Does this Max Authentication failures number that will trigger the Reauthentication Interval to count down for a specific client?
Thanks in advance for your help,
Best regards,
