Comware
  • 1.  LACP / Bridge Agg between 5945 & Cisco (model unknown)
    Posted Oct 09, 2021 06:57 AM
    I have to connect an IRF pair of HPE 5945’s to a pair of Cisco switches (model unknown currently). I have tested this offline and have got it working between a HPE & Cisco switch, however in production the IRF pair does not run any form of STP, is this likely to cause any issues?
    Matt.
    #Commware
    #Switch_Router_Interconnect
  • 2.  RE: LACP / Bridge Agg between 5945 & Cisco (model unknown)
    Posted Oct 09, 2021 07:06 AM
    Hi @MJB80 !
    STP is not a pre-requisite for a link-aggregation and if your IRF stack has STP disabled, it won't stop it from forming an aggregation. Just use 'link-aggregation mode dynamic' in order to have LACP-assisted aggregation. This will protect your network from incorrect wiring and potential loops that may happen over a miswired link-aggregation.
    If your Cisco swtiches use PVST+ or Rapid-PVST+ (in Cisco they love PVST, not sure why), maybe it's a good idea to enable it on the 5945 as well. Keep in mind your 5945 can speak that "lingo" too, just use 'stp mode pvst' in your 5945 IRF stack, so you are not limited to the standard MSTP (which will work fine too, but requires some planning to make PVST-MSTP interoperability trouble-free)
  • 3.  RE: LACP / Bridge Agg between 5945 & Cisco (model unknown)
    Posted Oct 09, 2021 11:32 AM
    Hi Ivan
    Thanks for the reply.
    The 5945 is the core of the network so would be a bit wary of enabling STP on the fly !
    I guess I just wanted to know that with STP disabled could an incorrectly configured LAGG between switches cause a loop? I could always disable STP on the Cisco switch if that would work in the short term?
    Matt.
  • 4.  RE: LACP / Bridge Agg between 5945 & Cisco (model unknown)
    Posted Oct 10, 2021 03:14 AM
    In general if STP is disabled and a LAGG is static (no protocol) then incorrect LAGG configuration and wiring may cause loops.
    However, if you use dynamic LAGG, then LACP protocol will try to protect you (as much as it can) from misconfiguration and miswiring.
    However, since LACP doesn't really care about VLAN mapping of connected ports it's quite easy to have a situation when both switches use different PVIDs (native VLANs) on the LAGG. In this case broadcast and multicast traffic can 'leak' from one VLAN to another creating loop situation. However, if LLDP is enabled it's got by default a PVID Inconsistency check enabled (you can disable it with 'lldp ignore-pvid-inconsistency' if needed) so it's another layer of protection from misconfiguration.
    There is one alternative for STP protocol - loop detection. The best thing about it is the fact it doesn't rely on adjacent device's support and compatibility, so you can enable it on the 5945 stack without changing anything in Cisco's config. And it doesn't require STP.
    Here is what the guide says about it:
    The device detects loops by sending detection frames and then checking whether these frames
    return to any port on the device. If they do, the device considers that the port is on a looped link.
    Loop detection usually works within a VLAN. If a detection frame is returned with a different VLAN
    tag than it was sent out with, an inter-VLAN loop has occurred. To remove the loop, examine the
    QinQ or VLAN mapping configuration for incorrect settings.
    The protocol is pretty lightweight - frames are small and are being sent every 30 seconds in each VLAN where the loop detection is enabled, so it won't cause any additional load on your network.
  • 5.  RE: LACP / Bridge Agg between 5945 & Cisco (model unknown)
    Posted Oct 10, 2021 04:11 AM
    Hi Ivan,
    Great response and definitely worth considering for future deployments . Can the loop protection be applied to the specific BAGG rather than globally on the switch or does it need to be turned on globally first?
    Matt.
  • 6.  RE: LACP / Bridge Agg between 5945 & Cisco (model unknown)
    Posted Oct 10, 2021 02:10 PM
    Hi Matt!
    Loopback-detection can be enabled globally or per port (BAGG as well).
    The Layer 2 Configuration Guide https://support.hpe.com/hpesc/public/docDisplay?docLocale=en_US&docId=a00098726en_us (page 248) says:
    You can enable loop detection globally or on a per-port basis. When a port receives a detection frame in any VLAN, the loop protection action is triggered on that port, regardless of whether loop detection is enabled on it.
    So in order to enable it on a BAGG you need the following config:
    system-view
    interface Bridge-Aggregation1
     loopback-detection enable vlan all
    The default action of the loopback detection is just log message generation in case of a loop.  Keep in mind that among 3 possible actions - 'block', 'no-learning' and 'shutdown' only 'shutdown' is supported on a BAGG. You can set the desired loopback detection action either globally or per port. Global action will affect all the ports where looopback-detection is activated. More details can be found in the abovementioned guide as well in the Layer 2 Command Reference Guide - https://support.hpe.com/hpesc/public/docDisplay?docLocale=en_US&docId=a00070972en_us
    Hope this helps!
