Hello community,
I have a weird mac-address-table problem in a rather complex network topology.
Problem Description
On SW3-5940-IRF client MAC addresses are learned (correctly) on the LAG interface to downstream access layer switch SW5-2930F-VSF. In this case the client which reports connectivity problems is connected to SW5.
Every few seconds the client mac address is seen on the LAG interface to SW1-5406zl and SW2-5406zl. This leads to packet loss of about 50% to 60% for the clients connected to SW5.
CLI Output which shows mac address change
[SW3/4-5940-IRF]display mac-address 0C54-1111-4444
MAC Address VLAN ID State Port/Nickname Aging
0C54-1111-4444 200 Learned BAGG4 Y
[L01DS000]display mac-address 0C54-15C6-FBBF
0C54-1111-4444 200 Learned BAGG150 Y
Firmware Versions
Switches SW1 and SW2 5406zl run firmware version K.16.02.0014
SW3 and SW4 (IRF): 5940 run firmware 7.1.070, Release 2612P02
Access Layer VSF switch SW5 and SW6: 2930F run firmware WC.16.08.0009
Topology Description
SW1-5406zl is connected to SW2-5406zl with a switch-interconnect on a trunk interface.
SW1-5406zl and SW2-5406zl have a distributed LACP trunk configured on the uplinks ports to SW3-5940-IRF. Both uplinks are conncted to one IRF switch. SW4-5940-IRF is the second IRF cluster member, but has no uplinks to SW1-5406zl and SW2-5406zl.
Clients are connected to access layer switch SW5-2930F-VSF and SW6-2930F-VSF. SW5-2930F-VSF has an uplink to SW3-5940-IRF and SW6-2930F-VSF to SW4-5940-IRF. This uplink is configured as a regular LACP LAG.
Temporary Solution
When I disable one uplink between SW3-5940-IRF and SW2-5406zl clients do not report any connectivity problems. The client mac addresses on SW3-5940-IRF are never shown on the uplink to SW1-5406zl.
To me it looks like a problem specific to distributed trunking with uplinks to IRF clusters. I also have another 5940 Comware Switch connected to SW1-5406zl and SW2-5406zl where I don't have this problem.
Has anybody found a similar problem?
Thanks in advance for your help
Tomorrow I will post the uplink configuration and a network topology map.
