Wired Intelligent Edge
LAG between two 8320 clusters for multiple VLANs
This thread has been viewed 56 times
  • 1.  LAG between two 8320 clusters for multiple VLANs
    Posted Nov 18, 2022 06:53 PM
    I have 2 VSX Clusters. One has 2 Fiber 8320s and the other is 2 Ethernet 8320s. I currently have two LAGs setup and working between the two clusters using the DAC ports. The LAGs are only one VLAN each.
    I was trying to setup another LAG between the clusters that would carry multiple other VLANs. I was using 1/1/51 for it. I have it set up just like the other LAGs that are working except instead of vlan access # I am using vlan trunk allowed #,#,#.​
    I set up 1 ethernet port on the two ethernet switches and added them to the LAG just to test and that worked. I was wondering, is there any reason why 1/1/51 would not work as a LAG with multiple VLANS? I read somewhere a few times that people had some issues doing something with LAGs, I forget what off hand, but I remember one thing said not sue the bottom row of ports on the swithces...
  • 2.  RE: LAG between two 8320 clusters for multiple VLANs
    Posted Nov 19, 2022 06:20 AM
    I have 8325 and use multi chassis LAG with the highest numbers ports (40g optics). They are trunk ports with multiple vlans. I can't think of any reason these would be different to ports 1-48.
    If it wasn't permitted because of hardware limitation i would expect a cli message when you configure.
  • 3.  RE: LAG between two 8320 clusters for multiple VLANs
    Posted Nov 19, 2022 07:48 AM
    Hi, you initially wrote "I currently have two LAGs setup and working between the two clusters using the DAC ports. The LAGs are only one VLAN each.".
    Just to clarify (maybe it's just me!), does the above sentence mean that your setup was made with two non-VSX LAGs (as you wrote, each one carrying one particular untagged VLAN id only) so it was made with normal LAGs (where a normal LAG is made of two or more physical interfaces of the same VSX member - the Primary or the Secondary - aggregated together instead of being made of two or more interfaces of both VSX members of a particular VSX cluster), say coming from the Primary or the Secondary and terminating to the other VSX cluster Primary or Secondary (or vice-versa) OR does the above sentence mean that your setup was made with two different VSX LAGs each one initiating and terminating in a distributed way on both VSX members of each VSX Cluster with its member interfaces?
    In other words...are you LAGging two VSX Clusters back to back (say from Primary to Primary, Secondary to Secondary or Primary to Secondary/Secondary to Primary) OR are you Multi-Chassis LAGging the first entire VSX cluater to you second entire VSX cluster?
    Then, is there reason you were forced to use two separate (supposedly non MC-LAGs = non VSX LAGs) to separately transport each one a VLAN ID when you could setup a VSX LAG back to back carrying multiple VLAN IDs and aggregating on each side (VSX cluster) up to four physical interfaces per VSX member (having a 4+4=8 ports links aggregation connected to the other VSX cluster)? Any relation with a related (M)STP setup?
  • 4.  RE: LAG between two 8320 clusters for multiple VLANs
    Posted Nov 19, 2022 08:09 AM
    Edited by parnassus Nov 20, 2022 05:19 AM
    ...and my above questions are not necessarily tied to the fact that, in my opinion, an "interlink among switches" (or among VSX clusters) - no matter if realized with just one single physical link or with multiple physical links aggregated together into a new logical interface (a LAG or a Multi-Chassis LAG) - should carry only tagged VLANs, the idea of working with an untagged VLAN's membership/transport is typically associated with (VLAN unaware) access devices (indeed you work with Native VLAN on ports designated with the Access/Edge role). Point to Point links generally carry multiple tagged VLAN and the Native VLAN could be, counter-intuitively, declared tagged too (in any case you should allow all of them).
  • 5.  RE: LAG between two 8320 clusters for multiple VLANs
    Posted Dec 28, 2022 04:10 PM
    Edited by sfpit1202 Dec 28, 2022 04:44 PM
    Hello, I am working on changing my LAGs to Multi-Chassis LAGs between the two clusters (That was my mistake, I did regular LAGs at first). Initially I just did int lag # on both sides. I am trying to do primary to secondary between the two clusters.
    I am seeing that the LAG shows as blocked by LACP. I did try adding lacp mode active to both ends and that did not help either.
    I configured it as follows and am wondering if I am missing something? I do have spanning-tree disabled also.
    configure terminal
    interface lag 50 multi-chassis
    no routing
    no shut
    interface 1/1/54
    no routing
    no shut
    lag 5
    interface lag 5
    vlan trunk allowed 2,3,4,5,6,7 etc...
    I see the ports lights on both ends, but it shows as blocked by lacp and I am not sure why. The only difference between this and the regular LAG configuration I have done is using multi-chassis. I am using HP DAC cables (JH234A) for all my LAGs as well.
  • 6.  RE: LAG between two 8320 clusters for multiple VLANs
    Posted Dec 29, 2022 02:48 AM
    Hi, The info you have posted suggests a LACP issue rather than config.
    Here is an example of a simple config that works:
    router1(config)# show run int 1/1/2
    interface 1/1/2
    no shutdown
    lag 24
    exit
    router1(config)# show run int lag 24
    interface lag 24 multi-chassis
    no shutdown
    no routing
    vlan trunk native 1
    vlan trunk allowed 5,114,200
    lacp mode active
    exit
    The output you attached shows passive LACP. Could this be caused by LACP not negotiating between two passive switches? What happens when you apply the "lacp mode active" and then bounce the physical ports?
    I also note the difference between the two VSX members and wonder if you have different configs on each member for the lag interface? It might be worth checking you have mclag-interfaces added to the VSX config (vsx...vsx-sync mclag-interfaces)
  • 7.  RE: LAG between two 8320 clusters for multiple VLANs
    Posted Jan 03, 2023 06:30 PM
    I have two VSX Clusters and I am going from the primary on one to the secondary on the other so I did not try the vsx-sync mclag-interfaces. I removed the lag and create one again. I have lacp mode active on both sides. If I try to change one to passive, I get a message that I cannot do that because it is part of a LAG. What I did notice is that if I use the static option (interface lag 55 multi-chassis static) the interfaces show up, but do not pass traffic (I cannot ping IPs on the other side).
  • 8.  RE: LAG between two 8320 clusters for multiple VLANs
    Posted Jan 03, 2023 11:48 PM
    Document - VSX Configuration Best Practices for Aruba CX 6400, 8320, 8325, 8360, 8400 v1.3 | HPE Support
    The document explains the whole idea of VSX clusters and how to set up MCLAGs.
    Cheers
    /timo
  • 9.  RE: LAG between two 8320 clusters for multiple VLANs
    Posted Jan 04, 2023 06:00 PM
    Edited by sfpit1202 Jan 04, 2023 06:02 PM
    This is my current setup. Cluster B picks up IP Address from DHCP Server setting I have configured on Cluster A. Both Clusters have VSX configured and working. Cluster A also has the DHCP Pools configured on it.
    I am trying to setup LAGs between the two clusters. I am going from the primary on Cluster A to the secondary on Cluster B and from the primary on Cluster B to the secondary on Cluster A. I had regular LAGs at first and they worked. This is how I had set them up:
    Interface lag 100
    no routing
    no shutdown
    vlan trunk naitve 1
    vlan trunk allowed 1,2,3,4,5
    lacp mode active
    int 1/1/53
    no routing
    no shut
    lag 100
    They all worked, and I could ping and see everything. I realized I want to use Multi-Chassis LAGs instead. I am doing the same configuration, but instead of interface lag 100, I am saying interface lag 100 multi-chassis. The LAG shows down and blocked by LACP when I do this. If I add the static option to the end, the LAG shows up, but passes no traffic. I have tried to do it using the simpler configuration from page 25 on VSX Configurations Best Practices Technical Whitepaper (I have been trying to do it like the example on page 26) which showed up for a little bit then went into blocked state again... The picture is what I am going for...
  • 10.  RE: LAG between two 8320 clusters for multiple VLANs
    Posted Jan 06, 2023 01:35 PM
    There is for sure something wrong with your setup: two well formed VSX clusters can easily be interconnected by using Layer 2 VSX LAG (Multi-Chassis LAG).
    Can you show us both current (sanitized) running configs? also the full show LAGs status?
  • 11.  RE: LAG between two 8320 clusters for multiple VLANs
    Posted Jan 10, 2023 11:37 AM
    I got frustrated and zeroized all of them then upgraded to the latest and greatest firmware I could find. I started out with just the basics of what I would need to get the LAGs set up and they showed up and passed traffic. I did not change how I set them up or anything. I added the rest of the configuration back and kept checking. They are all still good and I have them all configured now.
    I am not sure what the issue was, but I think something with the firmware version, maybe something went wrong when I updated them last time, I am not sure.
  • 12.  RE: LAG between two 8320 clusters for multiple VLANs
    Posted Jan 10, 2023 11:48 AM
    Might not be relevant here, but I came unstuck a couple of times when changing config on aspects of CX code. For example some bgp/ospf aspects needed a reboot or flush of instance.
    I hadn't seen that with VSX though.
