  • 1.  Large Scale Aruba Branch Wireless Networks - Design
    Posted Nov 01, 2022 01:38 PM
    I recently had a requirement to provide wireless connectivity to large number of branch sites, Encrypt all communication happening between the branch sites and the HQ, and rapidly deploy branch controllers/APs to provide WiFi access to hundreds of branches in a secure and efficient manner. Customer mandated that we should not use a Cloud-based solution.
    Although the Aruba Mobility Master, VPNCs and Branch Controllers running 8.x code could achieve this, it was hard to find a verified design document that captured this requirement. After spending days and months building and testing the solution, there is now a solution that is scalable, secure and cost-effective.
    Please feel to have a read , and leave your comments.
    Manjula
  • 2.  RE: Large Scale Aruba Branch Wireless Networks - Design
    Posted Nov 01, 2022 07:12 PM
    Here you can use this link to our updated Validated Solution Guides (VSG)
    https://www.arubanetworks.com/techdocs/VSG/docs/070-sd-branch-design/esp-sd-branch-design-000/
  • 3.  RE: Large Scale Aruba Branch Wireless Networks - Design
    Posted Nov 12, 2022 01:47 AM
    Thanks Aria,
    I am aware of the Aruba SD-Branch solution , however the customer did not want to use a Cloud based solution. so we built the solution entirely using 2 Mobility Masters and controllers and nothing else.
    -Hiripitiya
  • 4.  RE: Large Scale Aruba Branch Wireless Networks - Design
    Posted Nov 12, 2022 06:42 PM
    sure that will work too.
