Hi, you've asked quite a simple question but the answer is complex. In fact there are many books written on the subject. You are essentially asking which is the best datacentre network architecture.
To answer directly, yes stretching VLANs natively between datacentres will work if you have dark fibre or other optical circuits. I have two DCs connected like this. They are close, small and we own the land that the divergent fibres run. The services they house are legacy and so need L2 stretch. Is it a good idea in general? It Depends.
It is common that there is a need for the same VLANs to exist in both buildings. If a VM that attaches to a particular subnet moves to the other DC, it will likely need to be on the same VLAN. However, that doesn't mean to say you would simply put a LACP link between DCs. But you might.
If the DCs are small and simple and the paths that the fibres run are divergent, this might be the right solution. For anything else then you'll need to point the customer towards a DC network architect to understand if modern technologies like EVPN/VXLAN would better serve the need.
Original Message:
Sent: Jan 17, 2023 07:29 AM
Subject: Layer 2 extended between two Datacenters
My customer has two Datacenters connected using high bandwith redundant fiber links. Bandwith and latency are not an issue.
He wants that the two Datacenters share the same vlans, and want them extended between datacenters using normal L2 links.
In fact this means that what he wants is the two datacenters to be seen as a single big Datacenter.
This would probably work, but is it a good solution to extend vlans between two datacenters this way?
Have anybody seen this king of solution working?
Regards
