Since you've disallowed the RFP license, yes.
If you have a block of licenses that aren't in use then they can be transferred in the LMS. Contact TAC for assistance if necessary.
Original Message:
Sent: Aug 16, 2024 03:57 AM
Subject: Licensing - AOS 8.10 9240s
Thanks for clarifying this. So the license pool info below is still relevant and I will need to get more licenses (I still have 1,000 APs or so to transfer and it is showing the AP limit as 2939 if I'm reading that right?). Is it possible to transfer some unused licenses from our other cluster? I need to do these transfers next week.
University of Cambridge
Information Services
Wireless Team
Roger Needham Building
7 JJ Thomson Avenue
CB3 0RB
Original Message:
Sent: 8/15/2024 11:37:00 PM
Subject: RE: Licensing - AOS 8.10 9240s
Capacity licensing is not AP/PEF/RFP licensing. The 9240 gold capacity license allows the 9240 to run at full capacity: ~2000 APs. You'll still need the requisite number of AP/PEF/RFP licenses for the APs to operate within your environment.
Carson Hulcher, ACEX#110
Original Message:
Sent: Aug 15, 2024 02:44 PM
AOS 8.10.0.13
We have two active clusters, a main and an overflow, each with conductors and standby conductors, and failover clusters. Both are already in use serving APs.
We are transferring over a thousand additional APs from our main cluster to the overflow cluster in batches this/next week. The person who normally deals with the licensing is currently on leave and I'm just looking for some reassurance that I'm not going to hit the license limit during these transfers!
I'm told all of the 3 9240s in the overflow cluster have gold licenses (the conductor displays "Aruba9240_gold" for each md under the Capacity License tab) so as far as I'm aware that should give us 3 x 2000 licenses. But when I look on the Conductor GUI under Mobility Master -> License the global pool only shows just under 3,000 AP licenses. Are licenses managed differently on the 9240s? How do I see usage information for them to make sure we have enough?
Also how are the PEF licenses managed? Should Gold also give us 3 x 2000 PEF licenses?
<update> I found a couple of commands, 'show license capacity details' which does confirm the capacity is "A9240_gold", 'show license platform-limits' which appears to show there are 2048 AP and PEF licenses (as well as a bunch of others), and 'show license box' - but this shows a license table that has no entries. The first two are reassuring, not sure if I should be concerned about the 'show license box' output. I'd also like to find a command that tells me current usage and capacity for each box. </update>
Thank you,
Guy
