Have setup Clearpass 6.6 and HP MSM wireless network. I followed the HP MSM and Clearpass v3 guide to set up a .1x wireless network with PEAP with accounts in Active Directory. (Not guest portal)
The next step is to limit users in a sertain group in AD to only be able to connect with one device.
For checking the group i can use MemberOf. For number of devices I try to use Unique-Device-Count. If it is greater than 1 then deny access.
The problem is that when I connect multiple devices with the same usernaname the Unique-Device-Count counter is allways 1 when I look in access tracker.
I searched through Airheads and found some tips to add clearpass as accounting servers in the wireless controller, enable Radius interim accounting on the wireless controller and add Endpoint Repo to authorization sources.
None of these helped.
Do you have any idea why it doesn't work?
Regards
Philip
