Comware
  • 1.  Link Aggregation between 4210G and 5500
    Posted Aug 30, 2010 05:49 AM
    I'am trying to get a link aggregation SFP working between a 5500 (3CR17259-91 ) and 4210G (3CRS42G-24-91) in trunk mode, but it wont work only in access mode. what i want is a static aggregation (LACP enabled) in trunk mode it will only work when i change them to access ports.
    I have more aggregation links to the 5500 with 4200g (3CR17661-91 ) and that works fine LACP and Trunk mode between the switches, but not with the 4210G.
    Can anyone help me.
     display link-aggregation verbose
    4210G
    Loadsharing Type: Shar -- Loadsharing, NonS -- Non-Loadsharing
    Port Status: S -- Selected, U -- Unselected
    Flags:  A -- LACP_Activity, B -- LACP_Timeout, C -- Aggregation,
            D -- Synchronization, E -- Collecting, F -- Distributing,
            G -- Defaulted, H -- Expired
    Aggregation Interface: Bridge-Aggregation7
    Aggregation Mode: Dynamic
    System ID: 0x8000, 4001-c682-6161
    Local:
      Port             Status  Priority Oper-Key  Flag
      GE1/0/27         U       32768    1         {A}
      GE1/0/28         U       32768    1         {A}
    Remote:
      Actor            Partner Priority Oper-Key  SystemID               Flag
      GE1/0/27         16      32768    2         0x8000, 0016-e008-7080 {ACEFG}
      GE1/0/28         17      32768    2         0x8000, 0016-e008-7080 {ACG}
    5500 SFP
    Aggregation ID: 7,  AggregationType: Static,   Loadsharing Type: NonS
    Aggregation Description:
    System ID: 0x8000, 0016-e008-7080
    Local:
    Port                     Status  Priority  Key    Flag
    GigabitEthernet1/0/16    S       32768     2      {ACDEFG}
    GigabitEthernet1/0/17    U       32768     2      {ACG}
    Remote:
    Actor                    Partner Priority Key   SystemID                     Flag
    GigabitEthernet1/0/16    0       32768    0     0x8000,0000-0000-0000 {DEF}
    GigabitEthernet1/0/17    0       32768    0     0x8000,0000-0000-0000 {DEF}
    This message was edited by sleeb000 on 8-30-10 @ 3:27 AM
  • 2.  RE: Link Aggregation between 4210G and 5500
    Posted Aug 31, 2010 05:42 PM
    Maybe you have reached the maximum amount of Link Aggregation Groups on 4210G. I am not sure, but I think that the maximum groups you can create in the 4210G is up to eight groups, static or dynamic.
    HTH
  • 3.  RE: Link Aggregation between 4210G and 5500
    Posted Sep 01, 2010 05:12 AM
    Hi Fred,
    Thanks for responding, i have only one link aggregation on the 4210G, and 7 groups on the 5500. I have connected four 4200G with aggregation links to the 5500 with trunk ports but the 4210G will not work with the trunk only with access ports then the ports become selected and with trunk unselected.
  • 4.  RE: Link Aggregation between 4210G and 5500
    Posted Sep 03, 2010 04:56 PM
    Then make a double check in the port settings, this is weird. When the settings are exactly the same there is no way to malfunction. Anyway, certify that the cable is really ok. At last year I faced a problem with a Cat6 cable that was forcing a Etherchannel (Cisco) to came down.
    HTH
  • 5.  RE: Link Aggregation between 4210G and 5500
    Posted Mar 09, 2012 01:19 PM
    I know this is an old thread, but I am having the exact problem and I can't find anything on this.  I have two 4210-48G switches and when I to try aggregate (either static or LACP) *trunk* ports, they will not "select" and stay in the unselected state.  I have one other 4 port LAG going to another switch (static LAG, access ports) and it's working fine.  Before I spend anymore time of this...is this a known problem with the switches?  Is there an important step left out of the manual that makes this work?
  • 6.  RE: Link Aggregation between 4210G and 5500
    Posted Sep 04, 2012 09:17 AM
    the same problem and still not resolved .. anybody ??
  • 7.  RE: Link Aggregation between 4210G and 5500
    Posted Mar 29, 2013 05:18 AM
    First I inform you, that my english is poor :)
    I have the same problem and today I resolved it !
    If you want make a Link Aggregation beetwen 4210G and new A-series HP 5500 :
    1. Port link type to Access.
    2. Make Link Aggregation Static (LACP Disabled) or Dynamic (LACP Enabled) - on both switch the same.
    3. And now is importatnt ! On switch 5500 change link type LINK AGGREGATION - BAGG1 to trunk .
    No every port link type !
    Menu :
    Device->Port Mangement->Aggregation Port->BAGG1 (select it and change Link Type)
    4. On switch 4210G change link type every port belong to Link Aggreagtion to trunk !
    5. And now VLAN !
    On switch 550 you change vlan on BAGG1 ! Not on every port belong to Link Aggregation !
    Menu:
    Device->Network->Vlan->Modify Port->Aggregation Port->BAGG1
    6. On switch 4210g change vlan on every port belong to Link Aggregation.
    Best regards, Lukasz
