It's also available in 10.13.
link_resets_timestamp, link_speed, link_state, link_state_aggregate
Yes, link_resets_timestamp is not available before 10.13
PowerArubaCL: Powershell Module to use Aruba Central
ACEP / ACMX #107 / ACDX #1281
Original Message:
Sent: Jan 17, 2025 02:23 PM
Subject: Link State (Aruba CX) with API
Best, Gorazd
Gorazd Kikelj
MVP Guru 2024
Original Message:
Sent: Jan 17, 2025 02:21 PM
Yes. It's not timestamp but difference you need to subtract from current timestamp to get the correct timestamp when interface was transition to online.
Best, Gorazd
Gorazd Kikelj
MVP Guru 2024
Original Message:
Sent: Jan 17, 2025 02:16 PM
Oh yes...
Need to have API 10.13... we can't (yet) use pyaoscx...
but timestamp look strange (not unix time...)
Original Message:
Sent: Jan 17, 2025 01:41 PM
Looks like you will need to calculate link up time. You have link_resets_timestamp. I belive that you just subtract this value from current unix time.
Best, Gorazd
Gorazd Kikelj
MVP Guru 2024
Original Message:
Sent: Jan 17, 2025 01:18 PM
Hi Alex.
In 10.15. you have link_state, link_state_aggregate, link_state_hw available in Interface GET API.
Best, Gorazd
Gorazd Kikelj
MVP Guru 2024
Original Message:
Sent: Jan 17, 2025 06:37 AM
When you use show interface on Aruba CX, there is Link State with info about "uptime" of the port
Interface 1/1/1 is up
Admin state is up
Link state: up for 2 months (since Thu Nov 07 09:31:29 UTC 2024)
I search on the API call but no found where is this value...
