Comware
  • 1.  LLDP-MED on HPE 5900AT for voice VLAN?
    Posted Oct 08, 2016 06:32 AM
    Any good pointers for setup of VoIP Vlan on 5900 and between 5900 & Procurve 2920?
    Seb
  • 2.  RE: LLDP-MED on HPE 5900AT for voice VLAN?
    Posted Oct 10, 2016 06:34 PM
    Are you talking about the "auto voice" VLAN configuration?
    I'm sure the last time I looked I found that those "end user" features are not supported on those data centre class switches - best check the quickspecs or have a word with your local SE.
    2920 is dead easy - just needs "voice" keyword in the vlan config. Google is your friend, there are loads of articles on this very site and further afield.
    Ian
  • 3.  RE: LLDP-MED on HPE 5900AT for voice VLAN?
    Posted Oct 12, 2016 08:33 AM
    True, 2920 itself is not a problem.
    But this edge switch will be connected (as expected?) to the core, which is 5900 Stack in that case.
    So one would expect that some config will also needs to be applied to 5900 for it all to work
    And voice vlan commands are available on 5900, as per thread only few up
    These are ones I found so far: Using LLDP (CDP) with HP Comware and another thread on this board and HP Networking – Comware switches and Cisco IP telephones and LLDP Configuration and LLDP commands
    Seb
  • 4.  RE: LLDP-MED on HPE 5900AT for voice VLAN?
    Posted Oct 13, 2016 04:01 AM
    not sure what you mean. Since the 5900 is not doing any access, all it needs is to understand is the vlan-tagging. (that is the vlan needs to exist, and the vlan need to be allowed on relevant links.) the "difficult" part of tagging voice traffic differently from data is done by the 2920's accessports.
    Of course if you have some QoS-configuration. You need to make sure the 5900 is not remarking voice traffic as something else.
    Regards
  • 5.  RE: LLDP-MED on HPE 5900AT for voice VLAN?
    Posted May 09, 2017 04:17 AM
    While this might be true that there are not actually any IP Phones connected directly to 5900, but doing core switch duties, all satellite switches (HP 2920) connect to it. As so does Voice router itself on one of the ports
    Hence we want to do more than just Vlan tagging.
    We want to make sure that QoS policies are trusted etc, queues are set correctly, uplink ports are marked as voice-vlan ? etc
    Nice writetup is here:
    https://wantegrity.wordpress.com/2015/01/19/hp-networking-comware-switches-and-cisco-ip-telephones-part-2/
    but I am still trying to "translate" it to Comware 7 on 5900
    Also there is Voice VLAN Configuration (for 5820, did not find anything specific to 5900) here (ofcourse!? some commands are changed in current Comware 7 version!)
    And some commands from above simply give an error:
    In auto voice VLAN mode, voice VLAN can't be enabled on a trunk or a hybrid port that is already in a voice VLAN.
    Seb
