  • 1.  LLDP Spoofing?
    Posted Nov 25, 2016 11:38 AM
    We are looking at rolling out AAA authentication on our network. We use Aruba MAS switches and Aruba APs with Avaya IP phones. I was looking at setting up override conditions on the AAA Profile for the phones and APs to get diverted to a corporate access vlan and skip CPPM role assignment. for the APs I was planning to use a device-group ap profile to override the interface-group AAA profile. Similar to this:
    device-group ap
      enable
      switching-profile "AP"
    For the phones I was looking at setting a derivation rule on the AAA profile similar to this:
    aaa derivation-rules user test
      set vlan condition device-type equals "phone" set-value XXX
    My question is how secure is this setup? Can the proprietary LLDP TLVs be spoofed easily so that a hacker PC could mimic a phone or AP and get diverted straight into a corporate access vlan bypassing the rest of the AAA profile role assignment conditions?
  • 2.  RE: LLDP Spoofing?
    Posted Nov 26, 2016 06:04 AM
    LLDP can be easily spoofed (as can CDP). Tools to do so, like VoipHopper (CDP) and LLDP Generator (LLDP) are publicly available.
    Example with LLDP Generator:
    ./tool.py -p lldp -tlv sys-name "FakePhone" -tlv sys-desc "See, I can spoof LLDP" -tlv chid -ipv4 "123.45.67.89"
    Will show on your switch like:
    HPE-Aruba-Lab3810# show lldp info remote-device 4
     LLDP Remote Device Information Detail
      Local Port   : 4
      ChassisType  : network-address
      ChassisId    : 123.45.67.89
      PortType     : mac-address                            PortId       : 30 85 a9 aa aa aa                      SysName      : FakePhone
      System Descr : See, I can spoof LLDP                  PortDescr    :                                        Pvid         :
      System Capabilities Supported  :
      System Capabilities Enabled    :
      Remote Management Address
    I did not take the time so spoof the system capabilities, but that should not be that hard to fake your Avaya Phone. So it is okay to use LLDP as a convenience feature, probably not to use it as a securlty feature as there is no protection whatsoever in the protocol.
    The more secure solution would be to really authenticate the phone with 802.1X; the required securlty level depends on what is acceptable in your environment and was the outcome of the security assessment.
