  • 1.  Load Balancer
    Posted Oct 25, 2005 07:15 AM
    We use Foundry Load balancer for switching over to a different geographical environment. Sometime we have observed that after failing over to new geographical location it flip flop to previous geographical location.
    Can someone suggest why this is so ?
    Shiv
  • 2.  RE: Load Balancer
    Posted Oct 26, 2005 07:32 AM
    You might want to check the configuration on both boxes. I don't remember all of the details (it's been about 2 years since I worked with a Foundry box), but there are different failover modes that Foundry supports on different boxes. It could be that you are set up with box A as Master and box B as failover standby. If you failover from A to B, it could be that once B sees that A is again available, it may decide to normalize things and switch back.
    Allan
