  • 1.  load balancing
    Posted Dec 23, 2003 03:08 AM
    I have Proliant 1600 (Netware5+sp6a) server with two network adapters:
    - cpQNF3 (built - in)
    - 3Ñ 980 (PCI)
    As to me to expand the channel server - switch (3com switch 3300)having realized balance of the network traffic between these adapters
    (load balancing)
    Whether I can use both adapters with one address on TCPIP and in one network IPX.
    What means it to make, give the link to utilities and documents please.
  • 2.  RE: load balancing
    Posted Feb 04, 2004 04:24 AM
    Unless the NICs support "teaming", there is no way for you to effectively do load-balancing. The NICs will not be able to evenly distribute the load between themselves.
