Cloud Managed Networks
  • 1.  LOCAL OVERRIDES & CONFIGURATION SYNC ISSUES
    Posted Jul 08, 2020 11:08 AM
    We are getting a lot of pedding/failed changes which contain this config for the SFP port. We don't use LLDP on the SFP port does anybody know how to remove this.
    {"/lldp/local-port/49": 4}
  • 2.  RE: LOCAL OVERRIDES & CONFIGURATION SYNC ISSUES
    Posted Aug 20, 2020 08:09 AM
    Any news or progress on this matter?
  • 3.  RE: LOCAL OVERRIDES & CONFIGURATION SYNC ISSUES
    Posted Feb 02, 2021 12:45 PM
    any luck?  I am having this exact same issue
    Jamie Hopper
  • 4.  RE: LOCAL OVERRIDES & CONFIGURATION SYNC ISSUES
    Posted Feb 03, 2021 08:26 AM
    This may be a known issue if you are using SFP modules in these ports and using UI configuration. Fix seems expected in Central 2.5.3, but please reach out to Aruba Support if you need confirmation.
