  • 1.  Logon with 2 devices but "Unique-Device-Count" show as 1
    Posted Feb 27, 2018 10:39 PM
    Hi all,
    I'm using  "Unique-Device-Count" to limit number of devices can use to login with specific account at a moment but it doesn't work.
    I've test with some devices, all of them can login at the same time but on clearpass, "Unique-Device-Count"  show as 1 (i think it should be 2 if i test with 2 devices)
    Any one can help me resolve this issue?
    Many thanks for help
  • 2.  RE: Logon with 2 devices but "Unique-Device-Count" show as 1
    Posted Feb 27, 2018 11:00 PM
    Can you show a screen shot of the enforcement tab of your service
  • 3.  RE: Logon with 2 devices but "Unique-Device-Count" show as 1
    Posted Feb 27, 2018 11:21 PM
    Hi tarnold,
    This is my enforcement policy
  • 4.  RE: Logon with 2 devices but "Unique-Device-Count" show as 1
    Posted Feb 27, 2018 11:44 PM
    Service all look fine. need to look at the output. Looks like its sending an accept, so its not event stopping on the first line. I dont have a server access at the moment so I cant verify.
  • 5.  RE: Logon with 2 devices but "Unique-Device-Count" show as 1
    Posted Feb 27, 2018 11:54 PM
    What roles are you cacheing and why are you using roles if you have simple enforcement?
    Try unchecking cache roles. if you dont need them i would also just uncheck the roles.
  • 6.  RE: Logon with 2 devices but "Unique-Device-Count" show as 1
    Posted Mar 08, 2018 04:29 AM
    Hi
