Looking for Aruba 7220 Configuration Guide
This thread has been viewed 19 times
  • 1.  Looking for Aruba 7220 Configuration Guide
    Posted Sep 23, 2024 12:40 PM
    Edited by procopius1980 Sep 23, 2024 12:41 PM
    Hey Everyone!  Hopefully this is a simple request and I am just missing something obvious here.  I have a customer using two A7220s managed by Aruba Central.  They are running 10.6.0.3_90581 firmware.  Somehow the Aruba Cetnral IP/URL got changed to an erronious URL, and so now newly provisioned APs are not getting the correct config.  Aruba TAC has advised us to change the controllers to point to the correct URL.  However, I cannot find a configuration guide for the 7220 Mobility Controller for any version of Aruba OS 10.x code.  Can someone point me in the right direction, please?
    I just need to know how to change this change at the CLI level.  We've also requested TAC provide the instructons.  I was just suprised that I could not find a configuration guide on the Aruba Support page.
  • 2.  RE: Looking for Aruba 7220 Configuration Guide
    Posted Sep 23, 2024 03:25 PM
    Edited by chulcher Sep 23, 2024 03:25 PM
    Your best option is going to be factory defaulting that gateway and allowing ZTP to re-provision that gateway.  Do not use full setup, if you need to set a static IP then use the OTP option instead of ZTP.
    https://www.arubanetworks.com/techdocs/aos/aos10/migrate/gateways/
    The URL you're showing is for AOS-CX devices.
    https://www.arubanetworks.com/techdocs/central/2.5.8/content/nms/device-mgmt/communication_ports.htm
    Carson Hulcher, ACEX#110
