Comware
Loop detection on 5120-SI switches
  • 1.  Loop detection on 5120-SI switches
    Posted May 29, 2013 07:56 AM
    Hi!
    Recently we had a loop in one of our VLANs in our HP based network (10500 core-switches, 5120-SI access switches). Someone connected an unmanaged switch to two access ports of the same 5120-SI switch. This caused the broadcast packets to loop and consume bandwidth...
    The configuration of the 5120-SI switches includes
     stp bpdu-protection
     stp enable
    and for the GigabitEthernet interfaces
     port access vlan X
     stp edged-port enable
    What do I need to configure to prevent such a user-caused loop to happen again? I though of using storm-constrain or stp loop-guard. Is there a best-practices guide for these features (for example, how many pps to use for storm-constrain) or is anyone here in the community already using this features and could post a working config?
    Thanks!
    Leonardo
    #5120siloopguardbroadcaststorm
  • 2.  RE: Loop detection on 5120-SI switches
    Posted May 31, 2013 03:15 AM
    loopback-detection multi-port would be your soltution
    loopback-detection enable
    loopback-detection multi-port-mode enable
    interf giga x/y/z
    br
    Manuel
  • 3.  RE: Loop detection on 5120-SI switches
    Posted Jun 25, 2013 09:10 AM
    Hi Manuel,
    thank you!
    Regards, Leonardo
